586,112 active members*
3,068 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > 5 AXIS IMPELLER GIBBSCAM
    May 2015
    need some help with Gibbscam 5 axis impeller settings. i can program 3, 4 and 5 axis with no problems, but now i want to start programing turbo impellers and there is little to no info regarding impeller programming,
    any help will be greatly appreciated.
    Dec 2010
    50
    Re: 5 AXIS IMPELLER GIBBSCAM
    Go to 5axis tile
    In general -- first tab -- you have a down menu.
    Select ""turbo blade machining" is easy.
    If you need example send me your email.
    Enviado desde mi iPhone utilizando Tapatalk
    Aug 2010
    7
    e-mail
    I'll send you an example
    May 2015
    please post example here, so everyone can read and learn from it. thanks for the help
  1. Gouge marks on Impeller. 5-axis using TR-65
    By CryoTurbo in forum Fadal
    Last Post: 02-20-2013, 01:38 AM
  2. 4 Axis Impeller???
    By tobyaxis in forum Mastercam
    Last Post: 03-09-2009, 12:34 AM
  3. Updated:5-axis machining using unigraphics (impeller)?
    By thirumalkumarn in forum Uncategorised CAM Discussion
    Last Post: 02-16-2007, 09:26 AM
  4. GibbsCam 5 axis
    By cadman in forum Uncategorised CAM Discussion
    Last Post: 07-13-2003, 03:05 AM
