587,047 active members*
2,471 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Spindle Orientation Position Adjust
    Mar 2006
    255
    Question Spindle Orientation Position Adjust
    Hi all
    Does anybody know what parameter it would be to adjust the spindle when orientating to change tool. This is on a Fanuc OM control. The machine still works, but needs slight adjustment.
    I know its just a parameter, but can't remember which, so if anyone can help, this would be great.
    Pingu
    Apr 2005
    28
    hi,
    I believe it might be parameter 6577,i am not sure because i have other fanuc,i found this on google search:
    h**p://www.machinetoolhelp.com/Repairing/orientation.html
    hope it helps,
    ddanutz
    Feb 2005
    69
    We use parameter 4031 or 4077 but that is on 16 and 18 controllers.
    Nov 2006
    14
    use parameter no 6531
    calculation is 360 degree is represented by value 4096
    if you want to shift by say 180 degree you enter 2048 in this parameter
    if you want to shift by say 45 degree you enter 512 in this parameter
    Jan 2006
    59
    Spindle Orientation parameter on Fanuc 0M
    The spindle orientation parameter on the Fanuc 0M is #6577.
    I just did this for one of my customers!
    Robin
    :cheers:
