I have a question that I haven't found an answer to in the CamBam documentation on how to import an object like say
for example a DBxx connector that will be milled out via an inside profile? I see a need to be able
to import different drawing objects sort a like when you draw a PCB you pull in objects in this case pads etc. onto
a PCB design but in this case objects to mill or cut out say on a sheet of metal or what have you.
I found a DB9 DXF and I can bring that in and then make copies that i can move around but how do I bring in say another
DXF of some object that is different? For example a DB25 connector that is backside mounted along with say a couple
of more DB9's? Oh I haven't found a DXF of a DB25 yet so that would help too.
I would like to know if this can be done in CamBam with out to much difficulty.
Bruce
