586,111 active members*
3,584 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Wrapping a sheet metal part around another part with sketched bends?
    Oct 2006
    65
    I have a part with an irregular shape and I would like to fit another part around it. The 2nd part is defined as a sheet metal part so I can bend it and when it is straight apply some patterns to it. The problem is that I can't seem to find the right spot to insert the sketch so the bend will come out the way I want. How do you normally do this?
    Mar 2008
    683
    Re: Wrapping a sheet metal part around another part with sketched bends?
    Is this an assembly or a multi body part. Solidworks has only recently allowed multi body parts for sheet metal. It is still not easy to get multi body sheet metal parts in one part file.
    Get your master part as you want it and save it with a new configuration. Insert the configured part in a new assembly. Create a new part in assembly mode, extract what you want, then save the part.
    Hard to tell with your description and thumbnail but I think i get what you're trying to do.
  1. here's an interesting one. sheet metal part
    By kesparate in forum Solidworks
    Last Post: 08-01-2014, 11:28 PM
  2. Rolling a flat sheet metal part.
    By diyengineer in forum Solidworks
    Last Post: 04-12-2013, 12:28 PM
  3. sheet metal part problems
    By chadwiggan in forum Uncategorised CAD Discussion
    Last Post: 08-22-2010, 12:15 AM
  4. Turning tube into sheet metal part?
    By bearracecars in forum Solidworks
    Last Post: 08-14-2009, 04:36 AM
  5. What is best for sheet metal part modeling?
    By REVCAM_Bob in forum Uncategorised CAM Discussion
    Last Post: 01-25-2008, 06:05 PM
