586,036 active members*
4,343 visitors online*
IndustryArena Forum > WoodWorking Machines > Wood Lathes / Mills > DIY Mini Mill Router Machine by Slide Axis CNC and Aluminium Alloy Profile
    May 2015
    67
    Lightbulb DIY Mini Mill Router Machine by Slide Axis CNC and Aluminium Alloy Profile
    DIY Mini Mill Router Machine by Slide Axis CNC and Aluminium Alloy Profile very cheap
    Parts and Tools:
    4 or 6 or 8 SCS10UU 20 mm Linear Ball Bearing Motion Bearing CNC
    2 x 300 mm 20 mm Linear Rails
    2 x 400 mm 20 mm Linear Rails
    2 pcs Aluminium Alloy Profile 400 mm x 80 mm
    2 pcs Aluminium Alloy Profile 300 mm x 80 mm
    Aluminium Alloy 6061 400 mm x 120 mm x 12 mm.
    Linear shaft 25 mm x 600 mm aixs
    Linear shaft 11 mm x 300 mm aixs
    1 pcs SHF25 25mm Linear Rail Shaft Support XYZ Table
    1 pcs 25mm Linear Ball Bearing CNC
    May 2015
    67
    Re: DIY Mini Mill Router Machine by Slide Axis CNC and Aluminium Alloy Profile
    May 2015
    67
    May 2015
    67
    May 2015
    67
  1. CNC Aluminium profile machine needed
    By [email protected] in forum Want To Buy...Need help!
    Last Post: 01-10-2011, 06:48 AM
  2. BS1476 Aluminium Alloy SPEC
    By Gerry1955 in forum Material Machining Solutions
    Last Post: 03-25-2009, 10:47 AM
  3. Help with Y slide on HF Mini Mill
    By wdp67 in forum Benchtop Machines
    Last Post: 12-16-2007, 06:32 AM
