586,075 active members*
3,798 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal VMC15 convert to single phase
    Feb 2015
    9
    I bought a 1989 Fadal VMC 15 and am trying to convert it to single phase. I bought a new transformer and installed it. But the wiring diagram doesn't match my machine or wires. I seem to get axis faults from startup and can not clear it. It won't let me jog the machine to get to cold start. And recommendations would be helpful.
    Jun 2012
    516
    Re: Fadal VMC15 convert to single phase
    I can strongly recommend that you just buy a phase converter. you will be down on power, and acceleration if you run 1ph. I have a 20hp rotary and I run a 4020 with a 20hp high torque motor. it works fine. the 3ph converter will cost you about 900 bucks if you do it yourself / buy a phase craft converter or other brand from ebay and buy a motor locally.
    you axis faults and whatever could be anything though. its not necessarily because its 1 ph.
    Nov 2003
    287
    I have a VMC 15 with 15HP / 10,000 rpm spindle running just fine on single phase. It was originally wired for 3 phase. No transformer swap, just rewire in-coming power. I am sure it will depend which Servo drives you have and also which VFD. IF the drives run on 110V it shouldn't be a problem.
  1. Can I convert single phase motor to three phase?
    By Jim Estes in forum Phase Converters
    Last Post: 06-04-2020, 02:52 PM
  2. fadal on single phase
    By yeepman2 in forum Fadal
    Last Post: 05-22-2015, 03:10 AM
  3. Convert three phase transformer to single phase?
    By jimjovan in forum CNC Machine Related Electronics
    Last Post: 09-16-2013, 11:32 PM
  4. Single phase back to 3 ph VMC15
    By davisboys in forum Fadal
    Last Post: 04-06-2006, 01:26 AM
  5. Single phase Fadal
    By nervis1 in forum Fadal
    Last Post: 12-24-2003, 05:32 PM
