Hi Guys,
I have a problem with my Fadal VMC4020 spindle 10k rpm.
It worked fine till Friday and now in Monday morning after machine start it does not run with M3/M4 command.
It runs manually with command from the servo motor amplifier. It also moves with M19 to turn in position. But when you set S600 for example and start with M3/M4 it doen't move at all. The whole CPU freezes.
No warning or error messages on amplifier. No error messages on panel. Just freezes, keyboard not working and you must restart the machine to get it back in operation.
It seems that it receives the M command but the CPU waits for feedback signal, it never receives it and freezes.
I also have one VMC15, which is now working fine so I tried to change the signal board but the result was the same. Both boards work on the VMC15 so for me it looks like some kind of software problem.
If anybody know what I can do in this situation please help.
