1. Machine brief introduction :
We use top-quality four-row imported ball bearing, wide linear lead rail and self-lubricating block for the machine. It can balance the force in all directions to ensure the machine’s accuracy and strength when engraving.
The route of Z axis can be heightened to 1200mm, so it is suitable for processing large-scale and super-thick material.
The design documents of intelligent processing cross-border protection can prevent the excessive process caused by mechanical impact.
The diversified processing speed can be controlled separately. The speed of idle running and roll setting improve the quality of processed products and processing efficiency greatly.
2. Functional characteristics:
Adopt FANUC control system, high machining accuracy and high speed.
3. Application:
Wood, EPS, aluminum and non-metallic carbon hybrid materials.
4. Die and mold industries:
Soft metal and non-metallic mold: the machine is particularly suitable for automotive foam mold, wooden ship model, wooden model aviation, trains, other wooden and and soft metal mold.
Musical instrument industry:
Can carve three dimension musical instrument, contour cutting;
5. SAMPLES:
