586,052 active members*
4,263 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > Fanuc 3t: I need help, I need parameter manual and procedure
    May 2015
    Hi All,
    I am new to this forum, I hope someone can help me. We had an Old TAKAMATSU with FANUC 3T machine in our workshop.
    The problem is during boot-up, The message pop-up " sub memory not initialize" and afterwards Not ready message is blinking.
    I suspected the parameter is wipe out. Please somebody can help me?.
    best regards,
    Val1234
    24221
    Re: Fanuc 3t: I need help, I need parameter manual and procedure
    Do you have a print out of the original parameters, usually you see asterisks on the screen if the para are missing.
    Al.
    Albert E.
    May 2015
    Hi Al,
    I have a machine parameter print out, just recently found it in old file storage, But not sure if this is the correct one.
    I manually inputted to the machine, and I already re-initialize the sub memory. Only alarm now is "NOT READY".
    I cannot trace the Emergency signal because there is no Electrical Diagram. My number 1 problem now is how to obtain the machine Electrical Diagram.
    Anyway, thanks for the advice. I will try to get back to machine Supplier.
    best regards,
    Val1234
    Jun 2012
    I have a Takisawa 10T with Fanuc System 3T Model F.
    On start up after a while We get Sub Memory Not Initialized. Then Not Ready
    I removed the back up batteries once m/c powered up cleaned the contacts and fitted new batteries.
    How do we get the sub memory initialized
    Nov 2019
    21
    Quote Originally Posted by Proturn View Post
    On start up after a while We Sarkari Result Pnr Status 192.168.1.1 get Sub Memory Not Initialized. Then Not Ready
  1. Fanuc O-T parameter manual
    By Rocksalt in forum Fanuc
    Last Post: 04-04-2024, 03:35 AM
  2. Replies: 0
    Last Post: 05-14-2015, 11:12 AM
  3. I want to get about FANUC OL CNC parameter manual
    By michael lee in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-11-2014, 10:17 AM
  4. Machine parameter edit procedure for FANUC 6T System
    By VENKATESH REDDY in forum Fanuc
    Last Post: 10-13-2011, 10:56 PM
  5. Fanuc Parameter Manual
    By Garto in forum Fanuc
    Last Post: 06-23-2007, 04:31 AM
