586,111 active members*
3,522 visitors online*
Results 1 to 10 of 10
    Feb 2011
    212
    in need of a drawbar
    Anyone know where I can find a drawbar ? 1/2-13 thread fir a nmtb spindle
    Feb 2011
    212
    Re: in need of a drawbar
    To the top. I emailed charter oak about a week ago and no response . Send another email last night as well.
    Feb 2009
    152
    Oil hardened threaded rod from MSC
    Feb 2011
    212
    What about the nut on top ?
    Feb 2011
    212
    Just received an email 25$ so I'll be buying new
    - - - Updated - - -
    No your spam post does not help
    Quote Originally Posted by sudip View Post
    Jun 2004
    6618
    What caused the first one to go bad?
    If it wore out, then I would consider making my own. The replacement is likely the same grade material as the original. I use grade 8 threaded rod and coupling nuts. I bore through the nut and insert a roll pin. I find that it even has a better fit in the threads on the collet than the original DB.
    Lee
    Jun 2005
    1015
    kbc tools has them.
    Feb 2009
    152
    Use a coupler nut and turn it to fit inside your spindle, thread it on and then thread on another and weld it to the threaded rod. That's what you will get from the other guy for 25.00- for the same price you could make 3 yourself.
    Jun 2004
    6618
    Sometimes it is easier to buy than to make, however this is such a simple project that it takes virtually a few minutes work. You can be certain about the quality of the end result too. Not only that, but once you order the rod and nuts, you have future backup stock. I actually replaced my drawbar on my brand new machine when I received it. That way I know what it is made of.
    Lee
  1. 30Taper YCM30 Drawbar or power drawbar options.
    By countryguy in forum Knee Vertical Mills
    Last Post: 12-28-2014, 06:15 AM
  2. RFQ Drawbar
    By pearldiver in forum RFQ (Request for Quote)
    Last Post: 05-17-2013, 04:54 AM
  3. Drawbar
    By ALUM in forum Haas Mills
    Last Post: 09-09-2011, 03:52 PM
  4. Help with Air Drawbar
    By 387designs in forum MetalWork Discussion
    Last Post: 08-04-2009, 04:45 PM
  5. drawbar
    By advt001 in forum Cincinnati CNC
    Last Post: 11-24-2008, 12:49 AM
