Hi, I have been using trend cnc mini spiral downcut cutters for most of my cutting, (model aircraft bits). The most popular cutter I use is the 2mm diameter cutter with a 6mm cut depth. This causes a problem when cutting 1/4" balsa for obvious reasons.
Does anyone know of a uk supplier of spiral cutters, preferably 2mm diameter, that have a cut depth of greater than 6mm, 8mm would be ideal.
Mike
