Re: New air compressor recommendation
You need quiet?
1. Buy a Qunicy (traditional reciprocating). Good, quality American built with a quality 1800 rpm Baldor motor on it.
2. Build a lean too outside and mount the compressor outside your shop/garage....
3. Use the $9000 you saved to buy some more machine tools... A 5HP Kaiser runs $10.5k. A 5HP Quincy will run you $1.4k.
Maybe it doesn't make you neighbors happy, but it will make you happy.
Personally, I live with the 5HP Quincy in the corner of my garage. The noise isn't that bad, and it only takes a minute or two to fill the tank when it cycles. 15cfm at 150# will handle anything you throw at it. One of these days I will get motivated and build a sound enclosure around it and a through-wall intake. Actually, I am lying, I will probably just live with it 'cause I have dozens of projects higher up on the list.
If you just can't live without a screw compressor, Quincy makes a 5HP model that runs $4k.
If you can afford a Kaiser, than you probably should have a Haas in your shop to go with it, instead of a Tormach.
Back to the OP: my Quincy has a 30 gallon tank so it is relatively compact, sits in the corner underneath a shelf. 5HP was important to me as it is enough to drive just about anything you throw at it: pneumatic tools, plasma torch, sand blaster, etc.
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
