586,111 active members*
3,232 visitors online*
IndustryArena Forum > CAM Software > OneCNC > importing .dxf
Results 1 to 10 of 10
    Mar 2006
    19
    importing .dxf
    Hello all, im hoping someone can help me. Im new to Onecnc and am having a problem with importing a .dxf file from Autosketch into Onecnc. When i import the file some lines are obscure and out of scale i have tried R12 format and a few others. It gives me a warning that some parts of the file a not supported and tells me to save as R12 or explode before saving but it does not work. Please help!
    May 2005
    73
    Quote Originally Posted by ToddAnderson View Post
    trie explode and then (file) (drawing utlites) (purge) make sour that all layers are unlocked
    Mar 2006
    19
    Thanks ill try that
    Mar 2006
    19
    I got it sorted out a little, now when i import a R12 file from either acad07 or autosketch the lines have been broken into thousands of little segments. Anyone have this problem?
    Are they splines?
    Mar 2006
    19
    How do i find out if they are splines?
    In autocad, double click them to bring up the properties window. It will tell you the entity type at the top. Splines are converted to polylines with many segments when saved as v12 .dxf, which is why I asked.
    Mar 2006
    19
    Ok so if i import into autocad as splines, can i convert all the splines into polylines and then save into R12. Do you know an easy way of doing that?
    Saving as v12 .dxf DOES convert them to polylines. There isn't really an easier way, but there's a better way. You can download a lisp program for autoCAD that will let you specify how many segments the splines are converted to.
    http://new.cadalyst.com/code/browsey...llyear=2003#12
    http://new.cadalyst.com/code/browsey...ullyear=2006#1
    Mar 2006
    19
    Thanks for that, that helps. Its a little time consuming but i think it might work.
