586,437 active members*
3,851 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Coding > OpenCascade CAD for Windows - Mega Problems
Results 1 to 9 of 9
    Mar 2004
    761
    Thumbs up OpenCascade CAD for Windows - Mega Problems
    Does anyone here have OpenCascade CAD working with Windows?
    I downloaded the 'Demo' version and could not make heads or tails out of it. My last weekend was spent trying to get to work. Downloaded the (win) Python compiler to interface with it. Didn't work. Downloaded (win) FreeCAD and it did not work. I am about ready to give up on it for a second and final time.
    Wayne Hill
    Oct 2006
    46
    You too?!?!??! And I thought I was alone with my struggles under OCC... Where did you download from? (I assume from opencascade.org, but you know what happens when we assume...)
    Mar 2004
    761
    It would take a rocket scientist to figure how to use OCC on Windows.
    I downloaded it from www.opencascade.org
    My little matrix rotation program was easier to program than that.
    I used the Excel formula to map the 3D to 2D field. This does not help make chips, but does help show how a rotation matrix works.
    Code:
    #PBFORMS CREATED V1.50
    #COMPILE EXE
    #DIM ALL
    ' 3D Matrix Rotation by Wayne Hill -  PB/Win 7.0
    '   ** Includes **
    #PBFORMS BEGIN INCLUDES
    %USEMACROS = 1
    #IF NOT %DEF( %WINAPI )
    	#INCLUDE "WIN32API.INC"
    #ENDIF
    #IF NOT %DEF( %COMMCTRL_INC )
    	#INCLUDE "COMMCTRL.INC"
    #ENDIF
    #INCLUDE "PBForms.INC"
    #PBFORMS END INCLUDES
    '   ** Constants **
    #PBFORMS BEGIN CONSTANTS
    %frm_dialog = 101
    %cmd_draw = 102
    %IDC_MSCTLS_TRACKBAR32_1 = 104
    %IDC_MSCTLS_TRACKBAR32_2 = 105
    %IDC_MSCTLS_TRACKBAR32_3 = 106
    %IDC_LABEL1 = 107
    %IDC_LABEL2 = 108
    %IDC_LABEL3 = 109
    %IDC_LABEL4 = 110
    %IDC_LABEL5 = 111
    %IDC_LABEL6 = 112
    %IDC_MSCTLS_TRACKBAR32_4 = 113
    %IDC_LABEL7 = 114
    %IDC_LABEL8 = 115
    %IDC_BUTTON1 = 116
    %IDC_BUTTON2 = 117
    %IDC_BUTTON3 = 118
    %IDC_BUTTON4 = 119
    %IDC_BUTTON5 = 120
    %IDC_LABEL9 = 121
    %IDC_LABEL10 = 122
    #PBFORMS END CONSTANTS
    #INCLUDE "CCDraw.INC"		'CCDraw include file - See Below
    '   ** Declarations **
    DECLARE CALLBACK FUNCTION Showfrm_dialogProc( )
    DECLARE FUNCTION Showfrm_dialog( BYVAL hParent AS DWORD ) AS LONG
    DECLARE SUB SetTrackBars( hWnd AS LONG, X AS LONG, Y AS LONG, Z AS LONG )
    #PBFORMS DECLARATIONS
    '   ** Main Application Entry Point **
    FUNCTION PBMAIN( )
    	PBFormsInitComCtls( %ICC_WIN95_CLASSES OR %ICC_DATE_CLASSES OR %ICC_INTERNET_CLASSES )
    	Showfrm_dialog %HWND_DESKTOP
    END FUNCTION
    '   ** CallBacks **
    	LOCAL hTrackX AS DWORD
    	LOCAL hTrackY AS DWORD
    	LOCAL hTrackZ AS DWORD
    	LOCAL hScale AS DWORD
    	LOCAL hZoom AS LONG
    	LOCAL rc AS RECT
    	SELECT CASE AS LONG CBMSG
    		CASE %WM_SIZE		'resize control if parent is resized
    			IF CBWPARAM <> %SIZE_MINIMIZED THEN
    				GETWINDOWRECT ghCCD, rc		' get control's coordinates on screen
    				MAPWINDOWPOINTS 0, CBHNDL, rc, 2		' map result to dialog
    				SETWINDOWPOS ghCCD, 0, 0, 0, LOWRD( CBLPARAM ) - rc.nleft - 10, _		' width
    				  HIWRD( CBLPARAM ) - rc.nTop - 10, _		' height
    				  %SWP_NOMOVE OR %SWP_NOZORDER
    				INVALIDATERECT ghCCD, BYVAL %NULL, 0 : UPDATEWINDOW ghCCD		' Redraw Window
    			END IF
    		CASE %WM_HSCROLL
    			CONTROL HANDLE CBHNDL, %IDC_MSCTLS_TRACKBAR32_1 TO hTrackX
    			CONTROL HANDLE CBHNDL, %IDC_MSCTLS_TRACKBAR32_2 TO hTrackY
    			CONTROL HANDLE CBHNDL, %IDC_MSCTLS_TRACKBAR32_3 TO hTrackZ
    			CONTROL HANDLE CBHNDL, %IDC_MSCTLS_TRACKBAR32_4 TO hScale
    			gXROT = SENDMESSAGE( hTrackX, %TBM_GETPOS, 0, 0 )
    			CONTROL SET TEXT CBHNDL, %IDC_LABEL1, STR$( gXROT )
    			gYROT = SENDMESSAGE( hTrackY, %TBM_GETPOS, 0, 0 )
    			CONTROL SET TEXT CBHNDL, %IDC_LABEL2, STR$( gYROT )
    			gZROT = SENDMESSAGE( hTrackZ, %TBM_GETPOS, 0, 0 )
    			CONTROL SET TEXT CBHNDL, %IDC_LABEL3, STR$( gZROT )
    			gMScale = SENDMESSAGE( hScale, %TBM_GETPOS, 0, 0 )
    			CONTROL SET TEXT CBHNDL, %IDC_LABEL8, STR$( gMScale ) + "%"
    		CASE %WM_INITDIALOG
    			SENDMESSAGE hTrackX, %TBM_SETRANGE, %TRUE, MAKLNG( 0, 360 * 2 )		' Set min. & max. positions
    			SENDMESSAGE hTrackX, %TBM_SETPOS, %TRUE, 360		' Set current position
    			SENDMESSAGE hTrackY, %TBM_SETRANGE, %TRUE, MAKLNG( 0, 360 * 2 )		' Set min. & max. positions
    			SENDMESSAGE hTrackY, %TBM_SETPOS, %TRUE, 360		' Set current position
    			SENDMESSAGE hTrackZ, %TBM_SETRANGE, %TRUE, MAKLNG( 0, 360 * 2 )		' Set min. & max. positions
    			SENDMESSAGE hTrackZ, %TBM_SETPOS, %TRUE, 360		' Set current position
    			SENDMESSAGE hScale, %TBM_SETRANGE, %TRUE, MAKLNG( 1, 1500 )		' Set min. & max. positions
    			SENDMESSAGE hScale, %TBM_SETPOS, %TRUE, 100		' Set current position
    			gMScale = 100
    		CASE %WM_LBUTTONDOWN, %WM_LBUTTONDBLCLK		'start selrect draw
    			gMouseDownInParent = 1
    		CASE %WM_COMMAND
    			SELECT CASE AS LONG CBCTL
    				CASE %CMD_draw
    					IF CBCTLMSG = %BN_CLICKED OR CBCTLMSG = 1 THEN
    						DIALOG END CBHNDL
    					END IF
    				CASE %IDC_BUTTON1
    					IF CBCTLMSG = %BN_CLICKED THEN
    						gXRot = 360 : gYRot = 360 : gZRot = 360
    						SetTrackBars( CBHNDL, 360, 360, 360 )
    					END IF
    				CASE %IDC_BUTTON2
    						gXRot = 270 : gYRot = 360 : gZRot = 360
    						SetTrackBars( CBHNDL, 270, 360, 360 )
    					END IF
    				CASE %IDC_BUTTON3
    						gXRot = 270 : gYRot = 360 : gZRot = 270
    						SetTrackBars( CBHNDL, 270, 360, 270 )
    					END IF
    				CASE %IDC_BUTTON4
    						gXRot = 310 : gYRot = 360 : gZRot = 225
    						SetTrackBars( CBHNDL, 310, 360, 225 )
    					END IF
    				CASE %IDC_BUTTON5
    						CONTROL HANDLE CBHNDL, %IDC_BUTTON5 TO hZoom
    						IF SENDMESSAGE( hZoom, %BM_GETCHECK, 0, 0 ) = %BST_CHECKED THEN
    							gZoomStatus = 1		'On
    						ELSE
    							gZoomStatus = 0		'Off
    						END IF
    					END IF
    			END SELECT
    	END SELECT
    END FUNCTION
    '   ** Dialogs **
    	LOCAL lRslt AS LONG
    #PBFORMS BEGIN DIALOG %frm_dialog->->
    	LOCAL hDlg AS DWORD
    	DIALOG NEW hParent, "3D Matrix Rotation", 153, 51, 414, 357, %WS_POPUP _
    	  OR %WS_BORDER OR %WS_DLGFRAME OR %WS_SYSMENU OR %WS_MINIMIZEBOX OR _
    	  %WS_MAXIMIZEBOX OR %WS_CLIPSIBLINGS OR %WS_VISIBLE OR %DS_MODALFRAME _
    	  OR %DS_3DLOOK OR %DS_NOFAILCREATE OR %DS_SETFONT, %WS_EX_WINDOWEDGE _
    	  OR %WS_EX_CONTROLPARENT OR %WS_EX_LEFT OR %WS_EX_LTRREADING OR _
    	  %WS_EX_RIGHTSCROLLBAR, TO hDlg
    	CONTROL ADD BUTTON, hDlg, %cmd_draw, "Exit", 355, 10, 44, 16
    	CONTROL ADD "msctls_trackbar32", hDlg, %IDC_MSCTLS_TRACKBAR32_1, _
    	  "msctls_trackbar32_1", 25, 5, 305, 15, %WS_CHILD OR %WS_VISIBLE OR _
    	  %TBS_HORZ OR %TBS_BOTTOM
    	CONTROL ADD "msctls_trackbar32", hDlg, %IDC_MSCTLS_TRACKBAR32_2, _
    	  "msctls_trackbar32_2", 25, 20, 305, 15, %WS_CHILD OR %WS_VISIBLE OR _
    	CONTROL ADD "msctls_trackbar32", hDlg, %IDC_MSCTLS_TRACKBAR32_3, _
    	  "msctls_trackbar32_3", 25, 35, 305, 15, %WS_CHILD OR %WS_VISIBLE OR _
    	CONTROL ADD "msctls_trackbar32", hDlg, %IDC_MSCTLS_TRACKBAR32_4, _
    	  "msctls_trackbar32_4", 25, 50, 305, 15, %WS_CHILD OR %WS_VISIBLE OR _
    	CONTROL ADD LABEL, hDlg, %IDC_LABEL1, "360", 330, 5, 20, 10
    	CONTROL ADD LABEL, hDlg, %IDC_LABEL2, "360", 330, 20, 20, 10
    	CONTROL ADD LABEL, hDlg, %IDC_LABEL3, "360", 330, 35, 20, 10
    	CONTROL ADD LABEL, hDlg, %IDC_LABEL4, "X", 5, 5, 15, 10
    	CONTROL ADD LABEL, hDlg, %IDC_LABEL5, "Y", 5, 20, 15, 10
    	CONTROL ADD LABEL, hDlg, %IDC_LABEL6, "Z", 5, 35, 15, 10
    	CONTROL ADD LABEL, hDlg, %IDC_LABEL7, "Scale", 5, 50, 20, 10
    	CONTROL ADD LABEL, hDlg, %IDC_LABEL8, "100%", 330, 50, 30, 10
    	CONTROL ADD BUTTON, hDlg, %IDC_BUTTON1, "XY", 10, 70, 20, 15
    	CONTROL ADD BUTTON, hDlg, %IDC_BUTTON2, "XZ", 35, 70, 20, 15
    	CONTROL ADD BUTTON, hDlg, %IDC_BUTTON3, "YZ", 60, 70, 20, 15
    	CONTROL ADD BUTTON, hDlg, %IDC_BUTTON4, "ISO", 85, 70, 20, 15
    	CONTROL ADD BUTTON, hDlg, %IDC_BUTTON5, "Zoom", 110, 70, 30, 15, _
    	  %WS_CHILD OR %WS_VISIBLE OR %WS_TABSTOP OR %BS_TEXT OR _
    	  %BS_DEFPUSHBUTTON OR %BS_PUSHLIKE OR %BS_AUTOCHECKBOX OR %BS_CENTER _
    	  OR %BS_VCENTER, %WS_EX_LEFT OR %WS_EX_LTRREADING
    	DIALOG SEND hDlg, %DM_SETDEFID, %IDC_BUTTON5, 0
    	CONTROL ADD LABEL, hDlg, %IDC_LABEL9, "Label9", 155, 70, 55, 10
    	CONTROL ADD LABEL, hDlg, %IDC_LABEL10, "Label10", 215, 70, 50, 10
    #PBFORMS END DIALOG
    	ghCCD = CreateCcd( hDlg, %ID_CCD, 10, 90, 80, 60, _
    	  %WS_CHILD OR %WS_VISIBLE OR %WS_TABSTOP _
    	  , %WS_EX_CLIENTEDGE )
    	DIALOG SHOW MODAL hDlg, CALL Showfrm_dialogProc TO lRslt
    #PBFORMS BEGIN CLEANUP %frm_dialog
    #PBFORMS END CLEANUP
    	FUNCTION = lRslt
    END FUNCTION
    	CONTROL HANDLE hWnd, %IDC_MSCTLS_TRACKBAR32_1 TO hTrackX
    	CONTROL HANDLE hWnd, %IDC_MSCTLS_TRACKBAR32_2 TO hTrackY
    	CONTROL HANDLE hWnd, %IDC_MSCTLS_TRACKBAR32_3 TO hTrackZ
    	CONTROL HANDLE hWnd, %IDC_MSCTLS_TRACKBAR32_4 TO hScale
    	SENDMESSAGE hTrackX, %TBM_SETPOS, %TRUE, X
    	SENDMESSAGE hTrackY, %TBM_SETPOS, %TRUE, Y
    	SENDMESSAGE hTrackZ, %TBM_SETPOS, %TRUE, Z
    	gMscale = 100
    	gFirstTime = %TRUE
    	CONTROL SET TEXT hWnd, %IDC_LABEL1, STR$( gXROT )
    	CONTROL SET TEXT hWnd, %IDC_LABEL2, STR$( gYROT )
    	CONTROL SET TEXT hWnd, %IDC_LABEL3, STR$( gZROT )
    	CONTROL SET TEXT hWnd, %IDC_LABEL8, STR$( gMscale )
    END SUB
    ' CCDraw.INC, PB/Win 7.0 Custom Control Draw, by Wayne Hill.
    GLOBAL gXROT AS DOUBLE
    GLOBAL gYROT AS DOUBLE
    GLOBAL gZROT AS DOUBLE
    GLOBAL ghCCD AS LONG
    GLOBAL gMScale AS LONG
    GLOBAL gxGridZero AS LONG
    GLOBAL gyGridZero AS LONG
    GLOBAL gZoomStatus AS LONG
    GLOBAL gPt AS POINTAPI, gRc AS RECT
    GLOBAL gPrevPt AS POINTAPI
    GLOBAL gMouseDownInParent AS LONG
    GLOBAL gxOffset AS LONG, gYoffset AS LONG
    GLOBAL gFirstTime AS LONG
    'Equates
    %ID_CCD = 150
    DECLARE SUB Matrix( hWnd AS DWORD, X AS DOUBLE, Y AS DOUBLE, Z AS DOUBLE, Xpoint AS LONG, Xpoint AS LONG )
    DECLARE FUNCTION CreateCCD( BYVAL hWnd AS LONG, BYVAL CtrlId AS LONG, _
      BYVAL vLeft AS LONG, BYVAL vTop AS LONG, _
      BYVAL vWidth AS LONG, BYVAL vHeight AS LONG, _
      BYVAL wStyle AS LONG, BYVAL wStyleEx AS LONG ) AS LONG
    DECLARE FUNCTION ctlWndProc( BYVAL hWnd AS LONG, BYVAL wMsg AS LONG, _
      BYVAL wParam AS LONG, BYVAL lParam AS LONG ) AS LONG
    DECLARE FUNCTION ccdPaint( BYVAL hWnd AS LONG, BYVAL wParam AS LONG ) AS LONG
    DECLARE SUB DRAWCIRCLE( MemDC AS DWORD, hPen AS DWORD, fromX AS LONG, fromY AS LONG, ToX AS LONG, ToY AS LONG, radius AS LONG )
    DECLARE SUB DRAWLINE( MemDC AS DWORD, hPen AS DWORD, fromX AS LONG, fromY AS LONG, ToX AS LONG, ToY AS LONG )
    DECLARE SUB selRectBegin( BYVAL hWnd AS DWORD )
    DECLARE SUB selRectDraw( BYVAL hWnd AS DWORD, BYVAL x AS LONG, BYVAL y AS LONG )
    DECLARE SUB selRectEnd( BYVAL hWnd AS DWORD )
    SUB Matrix( hWnd AS DWORD, X AS DOUBLE, Y AS DOUBLE, Z AS DOUBLE, Xpoint AS LONG, Ypoint AS LONG )
    	LOCAL XSIN AS DOUBLE, YSIN AS DOUBLE, ZSIN AS DOUBLE
    	LOCAL XCOS AS DOUBLE, YCOS AS DOUBLE, ZCOS AS DOUBLE
    	LOCAL RMX1 AS DOUBLE, RMX2 AS DOUBLE, RMY1 AS DOUBLE
    	LOCAL RMY2 AS DOUBLE, RMZ1 AS DOUBLE, RMZ2 AS DOUBLE
    	LOCAL D2R AS DOUBLE
    	LOCAL wRect AS RECT
    	D2R = 0.0174532925199433
    	XSIN = SIN( gXROT * D2R ) : YSIN = SIN( gYROT * D2R ) : ZSIN = SIN( gZROT * D2R )
    	XCOS = COS( gXROT * D2R ) : YCOS = COS( gYROT * D2R ) : ZCOS = COS( gZROT * D2R )
    	RMX1 = YCOS * ZCOS
    	RMY1 = - ZSIN * YCOS
    	RMZ1 = YSIN
    	RMX2 = ZCOS * - YSIN * - XSIN + ZSIN * XCOS
    	RMY2 = - ZSIN * - YSIN * - XSIN + ZCOS * XCOS
    	RMZ2 = YCOS * - XSIN
    	Xpoint = (( X * RMX1 ) + ( Y * RMY1 ) + ( Z * RMZ1 )) * gMScale
    	Ypoint = (( X * RMX2 ) + ( Y * RMY2 ) + ( Z * RMZ2 )) * gMScale
    	IF SGN( Ypoint ) THEN Ypoint = - Ypoint		' Mirror -X for Dialog inverse
    	GETCLIENTRECT hWnd, wRect
    	gxOffset = ( wRect.nRight / 2 ) + gxGridZero
    	gyOffset = ( wRect.nBottom / 2 ) + gyGridZero
    	Xpoint = Xpoint + gxOffset
    	Ypoint = Ypoint + gyOffset
    END SUB
    ' Create control
    	LOCAL hCcd AS LONG
    	LOCAL wc AS WNDCLASSEX
    	LOCAL szClassName AS ASCIIZ * 20
    	szClassName = "CCDRAW"
    	IF GETCLASSINFOEX( GETMODULEHANDLE( BYVAL %NULL ), szClassName, wc ) = 0 THEN
    		wc.cbSize = SIZEOF( wc )
    		wc.style = %CS_DBLCLKS OR %CS_CLASSDC
    		wc.lpfnWndProc = CODEPTR( ctlWndProc )
    		wc.cbWndExtra = 4
    		wc.hInstance = GETMODULEHANDLE( BYVAL %NULL )
    		wc.hCursor = LOADCURSOR ( %NULL, BYVAL %IDC_CROSS )
    		wc.lpszClassName = VARPTR( szClassName )
    		REGISTERCLASSEX wc		'register new class
    		IF ERR THEN EXIT FUNCTION		'something bad
    	END IF
    	CONTROL ADD "CCDRAW", hWnd, CtrlId, "", vLeft, vTop, vWidth, vHeight, wStyle, wStyleEx
    	CONTROL HANDLE hWnd, CtrlId TO hCcd
    	gFirstTime = %TRUE
    	FUNCTION = hCcd		'return the handle
    END FUNCTION
    ' Main Message Handling
    	DIM HoldPos AS POINTAPI
    	LOCAL hDC AS LONG
    	SELECT CASE wMsg
    			selRectBegin hWnd
    			gMouseDownInParent = 0
    		CASE %WM_MOUSEMOVE
    			IF gMouseDownInParent THEN EXIT FUNCTION
    			GETCURSORPOS HoldPos
    			SCREENTOCLIENT hWnd, HoldPos
    			CONTROL SET TEXT GETPARENT( hWnd ), %IDC_LABEL9, STR$( HoldPos.x )
    			CONTROL SET TEXT GETPARENT( hWnd ), %IDC_LABEL10, STR$( HoldPos.y )
    			IF ( wParam AND %MK_LBUTTON ) THEN		'if mouse button is down while moved, draw rect
                selRectDraw hWnd, LOWRD( lParam ), HIWRD( lParam )
    			END IF
    		CASE %WM_LBUTTONUP		'mouse button released - end draw
    			selRectEnd hWnd
    		CASE %WM_ERASEBKGND : FUNCTION = 1		' Don't erase background
    		CASE %WM_PAINT : FUNCTION = ccdPaint( hWnd, wParam )
    		CASE %WM_DESTROY
    			hDc = GETDC( hWnd )
    			DELETEDC( hDC )
    		CASE ELSE : FUNCTION = DEFWINDOWPROC( hWnd, wMsg, wParam, lParam )		'default message processing
    	END SELECT
    END FUNCTION
    ' WM_PAINT message handler
    	LOCAL wRect AS RECT
    	LOCAL hBrush AS LONG
    	LOCAL YellowPen AS DWORD
    	LOCAL RedPen AS DWORD
    	LOCAL BluePen AS DWORD
    	LOCAL GreenPen AS DWORD
    	LOCAL BrownPen AS DWORD
    	LOCAL GridLine AS DWORD
    	'Create Pens
    	RedPen = CREATEPEN( %PS_SOLID, 10, RGB( 255, 0, 0 ))
    	YellowPen = CREATEPEN( %PS_SOLID, 10, RGB( 255, 255, 0 ))
    	GreenPen = CREATEPEN( %PS_SOLID, 10, RGB( 150, 255, 100 ))
    	BluePen = CREATEPEN( %PS_SOLID, 10, RGB( 0, 0, 255 ))
    	BrownPen = CREATEPEN( %PS_SOLID, 10, RGB( 150, 100, 50 ))
    	GridLine = CREATEPEN( %PS_DOT, 0, RGB( 0, 0, 0 ))
    	LOCAL hDC AS LONG
    	DIM mpx AS LONG
    	DIM mpy AS LONG
    	DIM mpx2 AS LONG
    	DIM mpy2 AS LONG
    	DIM Axes AS DOUBLE
    	DIM Cage AS DOUBLE
    	DIM Helix AS DOUBLE
    	DIM I AS LONG
    	DIM X AS DOUBLE, Y AS DOUBLE, Z AS DOUBLE
    	LOCAL hDCmem AS LONG
    	LOCAL hbmMem AS LONG
    	LOCAL hbmOld AS LONG
    	LOCAL hPen AS LONG
       Local PS As PAINTSTRUCT
    	CALL GETCLIENTRECT( hWnd, wRect )
       hDc = BeginPaint hWnd, PS
    	hDCmem = CREATECOMPATIBLEDC( hdc ) ' Create off-screen DC
    	hbmMem = CREATECOMPATIBLEBITMAP( hdc, wRect.nRight, wRect.nBottom )
    	hbmOld = SELECTOBJECT( hDCmem, hbmMem )
    	FILLRECT hDCmem, wRect, GETSTOCKOBJECT( %WHITE_BRUSH ) 'Paint Background
    	SETBKMODE hDCmem, %TRANSPARENT
    	Helix = .875
       ' Draw Quad Helix
    	FOR i = 0 TO 360 STEP 10
    		X = COS( I * ( 3.14159 / 180 )) * ( Helix )
    		Y = SIN( I * ( 3.14159 / 180 )) * ( Helix )
    		Z = ( Helix * 2 ) * ( i / 360 ) - Helix
    		Matrix( hWnd, X, Y, Z, mpx, mpy )
    		CALL DRAWCIRCLE( hDCmem, RedPen, mpx, mpy, mpx, mpy, 3 )
    		X = COS(( I + 90 ) * ( 3.14159 / 180 )) * ( Helix )
    		Y = SIN(( I + 90 ) * ( 3.14159 / 180 )) * ( Helix )
    		CALL DRAWCIRCLE( hDCmem, BluePen, mpx, mpy, mpx, mpy, 3 )
    		X = COS(( I + 180 ) * ( 3.14159 / 180 )) * ( Helix )
    		Y = SIN(( I + 180 ) * ( 3.14159 / 180 )) * ( Helix )
    		CALL DRAWCIRCLE( hDCmem, GreenPen, mpx, mpy, mpx, mpy, 3 )
    		X = COS(( I + 270 ) * ( 3.14159 / 180 )) * ( Helix )
    		Y = SIN(( I + 270 ) * ( 3.14159 / 180 )) * ( Helix )
    		CALL DRAWCIRCLE( hDCmem, YellowPen, mpx, mpy, mpx, mpy, 3 )
    	NEXT I
    	Cage = 1.0
    	' Draw cage
    	Matrix( hWnd, Cage, Cage, Cage, mpx, mpy )
    	Matrix( hWnd, - Cage, Cage, Cage, mpx2, mpy2 )
    	CALL DRAWLINE( hDCmem, GridLine, mpx, mpy, mpx2, mpy2 )
    	Matrix( hWnd, - Cage, - Cage, Cage, mpx, mpy )
    	CALL DRAWLINE( hDCmem, GridLine, mpx2, mpy2, mpx, mpy )
    	Matrix( hWnd, Cage, - Cage, Cage, mpx2, mpy2 )
    	Matrix( hWnd, Cage, Cage, - Cage, mpx2, mpy2 )
    	Matrix( hWnd, - Cage, Cage, - Cage, mpx, mpy )
    	Matrix( hWnd, - Cage, - Cage, - Cage, mpx2, mpy2 )
    	Matrix( hWnd, Cage, - Cage, - Cage, mpx, mpy )
    	Matrix( hWnd, - Cage, - Cage, - Cage, mpx, mpy )
    	Matrix( hWnd, - Cage, - Cage, Cage, mpx2, mpy2 )
    	' Draw Axes
    	Axes = 1.25
    	Matrix( hWnd, - Axes, 0, 0, mpx, mpy )
    	Matrix( hWnd, Axes, 0, 0, mpx2, mpy2 )
    	CALL DRAWLINE( hDCmem, GridLine, mpx, mpy, mpx2, mpy2 )		' X Axis
    	TEXTOUT hDCmem, mpx2, mpy2, "X", LEN( "X" )
    	Matrix( hWnd, 0, Axes, 0, mpx, mpy )
    	TEXTOUT hDCmem, mpx, mpy, "Y", LEN( "Y" )
    	Matrix( hWnd, 0, - Axes, 0, mpx2, mpy2 )
    	CALL DRAWLINE( hDCmem, GridLine, mpx, mpy, mpx2, mpy2 )		' Y Axis
    	Matrix( hWnd, 0, 0, Axes, mpx, mpy )
    	TEXTOUT hDCmem, mpx, mpy, "Z", LEN( "Z" )
    	Matrix( hWnd, 0, 0, - Axes, mpx2, mpy2 )
    	CALL DRAWLINE( hDCmem, GridLine, mpx, mpy, mpx2, mpy2 )		' Z Axis
    	IF gZoomStatus THEN		' Paint Zoom Window as needed
    		hBrush = SELECTOBJECT( hDCmem, GETSTOCKOBJECT( %NULL_BRUSH ))		'for hollow rect
    		hPen = SELECTOBJECT( hDCmem, CREATEPEN( %PS_SOLID, 2, GETSYSCOLOR ( %COLOR_3DSHADOW )))		'create pen
    		RECTANGLE hDCmem, gRc.nLeft, gRc.nTop, gRc.nRight + 1, gRc.nBottom + 1		'draw rect
    		DELETEOBJECT SELECTOBJECT( hDCmem, hPen )		'Destroy hPen
    		DELETEOBJECT SELECTOBJECT( hDCmem, hBrush )		'Destroy hBrush
    	END IF
        ' Copy Off-screen DC to Screen DC
    	BITBLT( hDC, wRect.nLeft, _
    	  wRect.nTop, wRect.nRight - wRect.nLeft, _
    	  wRect.nBottom - wRect.nTop, _
    	  hDCmem, 0, 0, %SRCCOPY )
    	SELECTOBJECT( hDCmem, hbmOld )
    	DELETEOBJECT hbmMem
    	DELETEDC( hDCmem )
       EndPaint hWnd, PS
    	'Destroy Pens
    	DELETEOBJECT RedPen
    	DELETEOBJECT YellowPen
    	DELETEOBJECT GreenPen
    	DELETEOBJECT BluePen
    	DELETEOBJECT BrownPen
    	DELETEOBJECT GridLine
    END FUNCTION
    	SELECTOBJECT( MemDC, hPen )		'Get Virtual Pen ready
    	ELLIPSE MemDC, fromX - radius, fromY - radius, ToX + radius, ToY + radius
    END SUB
    	DIM PrevPos AS POINTAPI
    	MOVETOEX MemDC, fromX, fromY, PrevPos		'Move Virtual Pen
    	LINETO MemDC, ToX, ToY		'Draw on Virual DC
    	MOVETOEX MemDC, PrevPos.x, PrevPos.y, PrevPos		'Return to previous postion
    END SUB
    	LOCAL rc AS RECT
    	SELECT CASE gZoomStatus
    		CASE 0
    			SETCAPTURE hWnd		' set capture to desired window
    			GETCLIENTRECT hWnd, rc		' get client size
    			MAPWINDOWPOINTS hWnd, 0, rc, 2		' map client coordiantes to screen
    			CLIPCURSOR rc		' clip cursor to client coordinates
    			GETCURSORPOS gPt		' get cursor pos on screen
    			SCREENTOCLIENT hWnd, gPt		' convert to client coordinates
    			gPrevPt.x = gPt.x		'INI Mouse Point X-Y
    			gPrevPt.y = gPt.y
    		CASE 1
    	END SELECT
    END SUB
    		CASE 0
    			gxGridZero = gxGridZero + ( gPt.X - gPrevPt.x )
    			gyGridZero = gyGridZero + ( gPt.Y - gPrevPt.Y )		'
    			gPrevPt.x = gPt.x		' Store Mouse Position X + Y
    			gPrevPt.y = gPt.y
    		CASE 1
    			' must make sure rect coordinates are correct,
    			' so right side always is larger than left, etc.
    			IF ( gPt.x < = x ) AND ( gPt.y > = y ) THEN
    				SETRECT gRc, gPt.x, y, x, gPt.y
    			ELSEIF ( gPt.x > x ) AND ( gPt.y > y ) THEN
    				SETRECT gRc, x, y, gPt.x, gPt.y
    			ELSEIF ( gPt.x > = x ) AND ( gPt.y < = y ) THEN
    				SETRECT gRc, x, gPt.y, gPt.x, y
    			ELSE
    				SETRECT gRc, gPt.x, gPt.y, x, y
    			END IF
    			IF gRc.nLeft = gRc.nRight THEN INCR gRc.nRight		'<- ensure we never get a "null rect"
    			IF gRc.nTop = gRc.nBottom THEN INCR gRc.nBottom
    			' Let Virtual DC do rectangle draw
    	END SELECT
    END SUB
    	LOCAL rc AS RECT
    	DIM CenterBox AS POINTAPI
    	DIM CenterScreen AS POINTAPI
    	LOCAL xs AS DOUBLE, ys AS DOUBLE
    	LOCAL hScale AS LONG
    	LOCAL NewScale AS LONG
    		CASE 0
    			RELEASECAPTURE
    			CLIPCURSOR BYVAL %NULL
    		CASE 1
    			RELEASECAPTURE
    			CenterScreen.x = Rc.nRight / 2
    			CenterScreen.y = Rc.nBottom / 2
    			CenterBox.x = ( gRc.nRight + gRc.nLeft ) / 2
    			CenterBox.y = ( gRc.nBottom + gRc.nTop ) / 2
    			' Scale Drawing by ratio of ZoomBox to Screen size
    			xs = rc.nRight \ ( gRc.nRight - gRc.nLeft )
    			ys = rc.nBottom \ ( gRc.nBottom - gRc.nTop )
    			NewScale = MAX( xs, ys )
    			' Calculate the difference from GridZero
    			' and center of screen then offset scale by difference.
    			gxOffset = ( CenterScreen.x - CenterBox.x )
    			gYoffset = ( CenterScreen.y - CenterBox.y )
    			gxGridZero = gxGridZero + ( gxOffset * xs )
    			gyGridZero = gyGridZero + ( gYoffset * ys )
    			gMscale = gMscale * NewScale
    			CONTROL HANDLE GETPARENT( hWnd ), %IDC_MSCTLS_TRACKBAR32_4 TO hScale
    			SENDMESSAGE hScale, %TBM_SETPOS, %TRUE, gMscale
    			CONTROL SET CHECK GETPARENT( hWnd ), %IDC_BUTTON5, 0
    			gZoomStatus = 0
    			CONTROL SET TEXT GETPARENT( hWnd ), %IDC_LABEL8, STR$( gMscale )
    			gRc.nLeft = 0
    			gRc.nTop = 0
    			gRc.nRight = 0
    			gRc.nBottom = 0
    	END SELECT
    END SUB
    Attached Files Attached Files
    Wayne Hill
    270
    Yes, Wayne, but just think what all you could do if you figured it out. I have manged to get the sample programs working. I think you needed .net for the latest build to work on windows, last I looked was in August, '06.
    FAS
    Mar 2004
    761
    Hi Fred,
    Yes, I did get the sample programs to run. I wanted to dig into the code structure and start working on a GUI. Yuck!!
    There is another option that was "found" in my Delphi library. It was there all along. No need to go out wandering aimlessly through the world of C++.
    Just wait about 6 months to see what I have dreamed up ...
    Wayne
    Wayne Hill
    Oct 2006
    46
    You working on an opensource cad/cam application with a nice GUI?!?!?? DO TELL!!!
    Mar 2004
    761
    It is an OpenGL library for Borland Delphi 7 with a Steema TeeChart interface. Not a true open source, but a better starting point than OpenCascade.
    I am too dumb to figure out the proper method of interfacing with OpenCascade through a C++ compiler. My tendancy is to find a better method that does not require the programmer to understand the inner workings of binary assembly language in order order to create useful programs.
    Wayne Hill
    Mar 2004
    32
    Quote Originally Posted by WayneHill View Post
    You may need to set some environment variables so your programs can find the OCC libraries.
    I'm not sure what you mean "demo version" - if you didn't download all of OCC, you probably need to do so.
    Also, OpenCascade is *NOT* a cad program. It could be used as PART of a cad program, but it is the backend only. They do include some demos, but they don't do anything terribly useful. That's what you're supposed to code!
    Mark
    Mar 2004
    761
    Mark,
    You has a good start on the Linux version of OCC. My trouble is in the windows version. OCC.org open souce is what I called a demo version. The samples were the demos. Didn't do much. I was not able to change or add any features in the windows version using the windows version of python. That is why I was looking for any help out there in the windows platform.
    Just got fed up with the whole thing and deleted it out of my computer.
    Wayne Hill
