We're having problems with our tool changer. It either stalls and errors when trying to retract or it retracts then errors. In both cases the error is: "ATC will not move into position". Also in both cases MDI says the previous tool is still in the spindle. We've cycled the connectors on the vertical movement sensor on the turret axle, the hall effect sensor for the Geneva drive and the two hall effect sensors on the Geneva arm. No change.
This one's a stumper.
