586,983 active members*
3,894 visitors online*
    Jul 2010
    38
    I messed up microstep step setting.
    This morning I found that when I switched from standard jog mode to microstep mode each axis move 1 inch now before stopping.
    I am at a loss at what in the world I did to change this. It worked fine before jogging only 1 step at a time. everything else functions fine..
    Thank you in advance for pointers
    Oct 2005
    1145
    Re: I messed up microstep step setting.
    Press the {TAB} key and then select whatever step length you want. Then press tthe {TAB} key again to return to the screen.
    (;-) TP
    Sep 2010
    717
    You can also change the steps by pressing Alt + J
    (Press Ctrl + J to change the jog mode; btw Cont. <-> Step.)
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
    Jul 2010
    38
    Thank You, Thank You.... That was the problem. Don't know how I managed to change that setting, but it is great to know it is there!
  1. Step setting changing on its own??
    By fish66 in forum Tormach PathPilot™
    Last Post: 03-27-2015, 05:30 PM
  2. Microstep Setting & Kernel Speed?
    By Contract_Pilot in forum Mach Software (ArtSoft software)
    Last Post: 01-25-2015, 10:11 PM
  3. Should I increase microstep setting
    By Georgie in forum DIY CNC Router Table Machines
    Last Post: 04-20-2009, 06:35 PM
  4. Half step vs quarter steep (microstep)
    By slavkok in forum Stepper Motors / Drives
    Last Post: 03-10-2008, 01:46 PM
