586,052 active members*
4,267 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Blue light staying on
    Just got this machine about a month ago, put a new light bulb in the blue light and when i turn the machine on it stays on all the time. any ideas why? There are inverter issues as well, maybe whoever did the work on it before we got it botched the wiring?
    Re: Blue light staying on
    it was the ELE-0070 RELAY, GRAYHILL SOLID STATE in the pendant, it says beacon next to it, found a spare in the bottom of my other machines cabinet, swapped em out, now it is off when its supposed to be and blinks when its supposed to.
    Apr 2005
    1194
    Isnt it nice Fadal supplied a small cache of extra relays and fuses
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
