586,075 active members*
3,768 visitors online*
    May 2015
    Hpr 260 edge quality issue
    Hi
    I currently operate a hpr 260 with an auto gas console and edge 2 controller. Just recently there is an issure with cut quality when cutting at 80A and 130A. When cutting 12mm plate at 130A the edge is not smooth. It has quite a jagged edge all the way along. All my consumables are correct and gas pressures are set as they should be. One thing i notice is that the machine does not sound as if its cutting smooth. ( i dont hear the consistent whistle that i do hear at 200A)
    This makes me think that there may be a fluctuation in the cut gas. I cant seem to get to the bottom of this issue. Is there valves or anything that may need changed in the gas console? Any help would be much appreciated. Thanks.
    Jan 2008
    2247
    Re: Hpr 260 edge quality issue
    Most likely there are some issues within the gas flow circuitry, although ensure that you have the correct stack up of consumable parts in your torch, verify by checking the part numbers with the operators manual, and that the parts are genuine Hypertherm parts. Best bet....as always....is to contact Hypertherm technical service. The techs that answer the phones are very well trained, very friendly and it is their top priority to get your system operating normally as quickly as possible.
    Jim Colt Hypertherm
    Dec 2012
    19
  1. Edge quality???
    By NorthridgeFab in forum Waterjet General Topics
    Last Post: 03-01-2012, 03:22 PM
  2. Edge quality cutting polycarbonate with 80 watt co2
    By lswonger in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-26-2011, 06:01 PM
  3. Quality Engineer/Quality manager - MI
    By MachiningJobs in forum Employment Opportunity
    Last Post: 04-04-2011, 10:51 PM
  4. Jim: Optimizing Small Hole Quality (Edge Control) - Pics
    By racesol in forum Hypertherm Plasma
    Last Post: 02-28-2011, 11:15 PM
  5. edge quality
    By tmbg in forum Hypertherm Plasma
    Last Post: 09-20-2010, 08:13 AM
