We need to replace the X axis thrust bearing and Hurco wants $1995 for a set of 2. Does anyone have the bearing number that is the same but less expensive.
Sorry. Hurco Part number 7130021128
Were you able to source these from someone else? Do you have a part number? Thanks!
Hahn Rossman
I pulled the assembly apart and the bearings are fafnir MM35BS72 QUH It looks like they are available as a set from bearing houses for about $850
Hahn Rossman
