586,111 active members*
3,192 visitors online*
Results 1 to 15 of 15
    Jan 2006
    77
    Is mach the one I need??
    I am building an light industrial router. (4'x5' ) . I have no experience with cnc and need to purchase the software. I have reviewed mach 3, checked out some videos, and listened to all you who recomend it. I have a friend who is headed in the direction of a full cnc machine shop (he is not a router guy) he just spent $4000 on - http://www.mecsoft.com/Mec/Products/products.shtml
    With Mach costing under $200, what am I missing? (I have asked him the same question, and he hasnt got back to me yet. Maybe he's thinking about it.)
    Thanks JK
    Mar 2004
    1543
    I know nothing of this product, but I see the web site talks mostly about the CAM abilities it has. Mach has no CAM, its a machine control package. You have to get that separately.
    In general, I wouldn't get a "Jack of all trades, master of none" software. Get the best machine control package, Mach3, in your price range. And then get CAD/CAM software separately. I'd suggest you start with any CAD drawing package you like and use NCPlot to generate Gcode.
    Karl
    Jan 2006
    77
    I am confused. So Mach 3 generates g code? what is cam. I know it is an elementary question but I just dont get something here.
    Thanks JK
    Visual Mill creates the g-code. Mach 3 reads it and controls the machine.
    Jan 2006
    77
    OK, I have issues. Nothing new.
    I have a good cad program (Solidedge), and I buy Mach 3 to read the g code, what generates the G code ?
    JK
    Jul 2004
    442
    You draw in CAD
    You generate G-code with CAM
    Mach interprets the code and sends signals to the drivers
    The drivers run the steppers or servos that move the axis'
    Jerry
    Jul 2004
    442
    Mach can also generate some code. A program called Lazycam can be downloaded from the same site. It will get you started and you'll learn whether you need something like Visual Cam. Depending on what you'll be doing Lazycam may be all you need.
    Jerry
    Jan 2006
    77
    Quote Originally Posted by ozzie34231 View Post
    You draw in CAD
    Jerry
    Thank you thank you, Jerry. How simple is that. I get it. My buddy that spent $4k on his software has replied to my question to him and said that maybe Mach 3 can work directly from a dxf file. He was guessing. What is the truth?
    I'm glad I only have to go through this learning curve once.
    JK
    LazyCAM can convert .dxf's to g-code, but it can be a bit buggy, depending on the particular .dxf's
    You can download Mach3 and play around with it. Near the end of the install, uncheck the box that syas "install driver". This will install it in simulation mode, so it won't hog your PC while it's running. LazyCAM can be found under the file menu in Mach3. Downloaded the newest 2.0xxx series version.
    Jan 2006
    77
    Ok It is sinking in. Thanks to you too, Gerry, you said about the same thing, I just didnt get it.
    What will I be doing? Some reasonably complex foam and wood tooling for vacuum forming. Roughly the size of a small suitcase.( That would be the biggest)
    I create some pretty wild stuff with cad.
    Having said that, any direction on the creation of G code?
    Is there a better forum to post this question on?
    any sugested reading?
    any perfered software that doesnt cost $4k ?
    Dont you just love us rookies?
    Thanks a lot guys JK
    Jul 2004
    442
    If you create wild things you should look at CNC Toolkit. There is a Yahoo group and Rinnea's own site. The Toolkit is a plug-in for 3DS Max and creates 3,4, or 5 axis toolpaths. A few guys are doing fantastic thiongs with it.( like inlays for pool cues!)
    I don't know if solidedge will export in a format compatible with 3DS Max but if it does that may be the way to go. The Toolkit is free right now and there is a free version of 3ds Max called Gmax. I don't remember the limitations of the freebee.
    I advise you to spend a lot of time delving and working with demos before you spend a few thou on a CAM program, you may not have to.
    Everyone thought a control program had top cost 10 or 20 thou until Art started his Mach creations. It's world class now for less than $200!
    Aug 2005
    828
    Mach was the first machine controller that I started with and love it!! If it wasn't for Mach I would still not have any CNC machinery. Now I got a second Bridgeport to retrofit with Mach.
    Dennis
    Feb 2006
    49
    Dennis, Have you got this BP retrofit done yet? What accuracy do you expect? What control hardware do you plan to use? I am planning a retrofit to a Shiz AN-S mill and would appreciate your insights.
    Doug Danielson
    Aug 2005
    828
    It took me a while to figure out how the pneumatic drawbar works on this thing. But I got it now. I pulled the original DC spindle motor out and will use a regular AC motor with a VFD. For the stepper drives I got four Parker CD80M 140 volt 7 amp drives, should make the motors scream. I was also waiting for Ron Rogers and Briam Barker to finish up the encoder interface card (http://www.rogersmachine.net/encoderinterface.html)so I can put in the mill. If there is a tracking error (user set) Mach will stop the motors and wait till you correct it. Next few weeks I will have a lot more progress.
    Dennis
