586,119 active members*
3,645 visitors online*
    Oct 2009
    75
    Joining Multiple .tap Files
    Is there a good way to join (concatenate) 4 separate .tap files into one file? Each file has separate subroutines.
    If someone could point me to an example, that would be helpful.
    Greg
    Aug 2010
    128
    Re: Joining Multiple .tap Files
    Can't just cut and paste?
    Dec 2008
    3109
    Quote Originally Posted by abcmojave View Post
    Careful..... with cut & paste
    subroutine names need to be individualised, call-up a sub and it would probably run the 1st one found....not exactly what you want
    Can you create a separate file that calls up the file you need to run concurrently, this would be the file you load to run,
    - the files being called should also reside in the same location
    ie
    O0005
    N1 M98 P0001 Q1
    N2 M98 P0002 Q1
    N3 M98 P0003 Q1
    N4 M98 P0004 Q1
    M30
    M98 is a simple sub call, P is the program number, Q is the number of repetitions ( can be omitted if only 1 repeat )
    M99 may need to be placed at the end of the called programs instead of M2/M30
  1. Exporting Multiple Files
    By Starleper1 in forum Solidworks
    Last Post: 07-23-2011, 06:42 PM
  2. PDF files, multiple lines, RC foam cutting
    By red2 in forum CNC Wire Foam Cutter Machines
    Last Post: 07-20-2011, 01:36 PM
  3. Plotting files with multiple fixture offsets
    By Neziah in forum NCPlot G-Code editor / backplotter
    Last Post: 04-25-2011, 08:31 PM
  4. first attempt at multiple 3d files
    By jrj5x5 in forum Camaster
    Last Post: 02-09-2010, 01:27 AM
