Hello I have just downloaded the trial and I really like it with my new rotary!
Before what I would do is make two halves of a corbel and then glue the flat side back to back the carved portion facing outward. Problem was nearly everything would warp no matter what I did.
Now I have been able to combine the model with meshmixer and cut both sides with two sided cut mode but the model is off from top to the bottom of the board on the Y plane when its cut.
I have bored the holes that hold down the rotary drive and the tailstock with the machine itself so I do not think that could be out of alignment, I also used a v-bit to set Y to the tailstock point.
I would like to switch to rotary mode and cut it like I would a chair leg, however it would have lots of air cutting because the software assumes my stock is equal on all sides. Is there anyway to change this?
