586,121 active members*
3,373 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540..Stupid fuse wiring question?
    Nov 2006
    14
    I'm trying to find out where to put the fuse holder for the G540. Right now I have it between the G540 and the power supply. I've read that it goes between the AC input and the power supply, but that doesn't seem like it would protect the Gecko. Or do I have the wrong idea and it's supposed to protect the entire unit?(between AC input and power supply) Also what is the correct amperage fuse that I use? Thank in advance.
    Adam
    Nov 2006
    14
    Re: G540..Stupid fuse wiring question?
    Does anyone know this or is it such a dumb question that nobody wants to answer. I'm just trying not to fry my G540. 110 Views, no replies. Thanks
    Adam
    May 2015
    33
    Quote Originally Posted by slashr76 View Post
    Adam
    Hey Adam, Yep, yes and Yeah. we are all pretty shy.
    Check with the mob you bought your gear from.
    A "spec" sheet is another way to get an answer.
    I googled this. http://www.geckodrive.com/support/mo...540-rev-8.html
    Now, I'm not going to read this for you, but just quickly there seem to a few '(Do's and Don'ts).
    Of the top of my head, what you read, seems to be correct. Fuse the AC I/P.
    Luck with it mate,
    Mark Needham
  1. Another g540 VFD wiring question
    By DIRKHALLSZ in forum Gecko Drives
    Last Post: 11-02-2014, 12:16 AM
  2. Easy stupid stepper wiring question
    By jonesturf in forum Uncategorised MetalWorking Machines
    Last Post: 02-10-2014, 05:19 PM
  3. Another sPID, G540, and Mach wiring question for the wiring challenged..
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-02-2014, 01:29 AM
  4. G540 Motor wiring question
    By HuntinDoug in forum Gecko Drives
    Last Post: 03-31-2012, 03:57 PM
  5. X2 G540 Wiring Question
    By Steoh in forum Benchtop Machines
    Last Post: 03-02-2011, 01:53 AM
