586,077 active members*
3,938 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Buffer starvation error with Mach3+Kflop/Kanalog
Results 1 to 7 of 7
    Jun 2013
    7
    I am having a problem with my machine.
    Every time I try to run a gcode file bigger than 1300 lines I get buffer starvation error on the 4th ot 5th line.
    I tried to switch to a better computer ( intel i3 4gb ram) and it did the same problem.
    What's wrong?
    May 2006
    4045
    Re: Buffer starvation error with Mach3+Kflop/Kanalog
    Hi mitzpetel,
    Do you have a Mach3 License? Does it show in the About Dialog? What Version of Mach3? What Version of KMotion? What Buffer Time do you have set in the Dynomotion Plugin?
    Regards
    TK
    http://dynomotion.com
    Jun 2013
    7
    The Mach3 is licensed and I am using the latest versions of kmotion (4.32) and mach3 (3.043.66)
    The exact message it shows is "Unexpected motion buffer starved"
    this is the init file:
    #include "KMotionDef.h"
    #define QA 26 // define to which IO bits the AB signals are connected
    #define QB 27
    main()
    int BitA,Change1=0,Change2=0, DiffX2;
    int PosNoWrap, NewPos, Pos=0, wraps;
    double Factor=0;
    FPGA(STEP_PULSE_LENGTH_ADD)=32;
    SetBit(146);
    SetBit(147);
    SetBit(148);
    ch0->InputMode=ENCODER_MODE;
    ch0->OutputMode=DAC_SERVO_MODE;
    ch0->Vel=1000000;
    ch0->Accel=4000000;
    ch0->Jerk=2e+006;
    ch0->P=0.35;
    ch0->I=0.004;
    ch0->D=0.01;
    ch0->FFAccel=0;
    ch0->FFVel=0;
    ch0->MaxI=300;
    ch0->MaxErr=5000;
    ch0->MaxOutput=2000;
    ch0->DeadBandGain=1;
    ch0->DeadBandRange=10;
    ch0->InputChan0=0;
    ch0->InputChan1=1;
    ch0->OutputChan0=0;
    ch0->OutputChan1=1;
    ch0->MasterAxis=-1;
    ch0->LimitSwitchOptions=0x105;
    ch0->LimitSwitchNegBit=136;
    ch0->LimitSwitchPosBit=0;
    ch0->SoftLimitPos=1e+009;
    ch0->SoftLimitNeg=-1e+009;
    ch0->InputGain0=-1;
    ch0->InputGain1=-1;
    ch0->InputOffset0=0;
    ch0->InputOffset1=0;
    ch0->OutputGain=-1;
    ch0->OutputOffset=0;
    ch0->SlaveGain=1;
    ch0->BacklashMode=BACKLASH_OFF;
    ch0->BacklashAmount=0;
    ch0->BacklashRate=0;
    ch0->invDistPerCycle=1;
    ch0->Lead=0;
    ch0->MaxFollowingError=100;
    ch0->StepperAmplitude=250;
    ch0->iir[0].B0=1;
    ch0->iir[0].B1=0;
    ch0->iir[0].B2=0;
    ch0->iir[0].A1=0;
    ch0->iir[0].A2=0;
    ch0->iir[1].B0=1;
    ch0->iir[1].B1=0;
    ch0->iir[1].B2=0;
    ch0->iir[1].A1=0;
    ch0->iir[1].A2=0;
    ch0->iir[2].B0=1;
    ch0->iir[2].B1=0;
    ch0->iir[2].B2=0;
    ch0->iir[2].A1=0;
    ch0->iir[2].A2=0;
    EnableAxisDest(0,0);
    ch1->InputMode=ENCODER_MODE;
    ch1->OutputMode=DAC_SERVO_MODE;
    ch1->Vel=800000;
    ch1->Accel=4000000;
    ch1->Jerk=4e+006;
    ch1->P=1.3;
    ch1->I=0.003;
    ch1->D=0.001;
    ch1->FFAccel=0;
    ch1->FFVel=0;
    ch1->MaxI=2000;
    ch1->MaxErr=100;
    ch1->MaxOutput=2000;
    ch1->DeadBandGain=1;
    ch1->DeadBandRange=0;
    ch1->InputChan0=1;
    ch1->InputChan1=1;
    ch1->OutputChan0=1;
    ch1->OutputChan1=1;
    ch1->MasterAxis=-1;
    ch1->LimitSwitchOptions=0x121;
    ch1->LimitSwitchNegBit=137;
    ch1->LimitSwitchPosBit=0;
    ch1->SoftLimitPos=1e+009;
    ch1->SoftLimitNeg=-1e+009;
    ch1->InputGain0=-1;
    ch1->InputGain1=1;
    ch1->InputOffset0=0;
    ch1->InputOffset1=0;
    ch1->OutputGain=-1;
    ch1->OutputOffset=0;
    ch1->SlaveGain=1;
    ch1->BacklashMode=BACKLASH_OFF;
    ch1->BacklashAmount=0;
    ch1->BacklashRate=0;
    ch1->invDistPerCycle=1;
    ch1->Lead=0;
    ch1->MaxFollowingError=50;
    ch1->StepperAmplitude=250;
    ch1->iir[0].B0=1;
    ch1->iir[0].B1=0;
    ch1->iir[0].B2=0;
    ch1->iir[0].A1=0;
    ch1->iir[0].A2=0;
    ch1->iir[1].B0=1;
    ch1->iir[1].B1=0;
    ch1->iir[1].B2=0;
    ch1->iir[1].A1=0;
    ch1->iir[1].A2=0;
    ch1->iir[2].B0=1;
    ch1->iir[2].B1=0;
    ch1->iir[2].B2=0;
    ch1->iir[2].A1=0;
    ch1->iir[2].A2=0;
    EnableAxisDest(1,0);
    ch2->InputMode=NO_INPUT_MODE;
    ch2->OutputMode=STEP_DIR_MODE;
    ch2->Vel=500;
    ch2->Accel=200;
    ch2->Jerk=6e+006;
    ch2->P=1;
    ch2->I=0;
    ch2->D=0;
    ch2->FFAccel=500;
    ch2->FFVel=0;
    ch2->MaxI=2000;
    ch2->MaxErr=1e+008;
    ch2->MaxOutput=2000;
    ch2->DeadBandGain=1;
    ch2->DeadBandRange=0;
    ch2->InputChan0=4;
    ch2->InputChan1=1;
    ch2->OutputChan0=12;
    ch2->OutputChan1=1;
    ch2->MasterAxis=-1;
    ch2->LimitSwitchOptions=0x120;
    ch2->LimitSwitchNegBit=138;
    ch2->LimitSwitchPosBit=0;
    ch2->SoftLimitPos=1e+009;
    ch2->SoftLimitNeg=-1e+009;
    ch2->InputGain0=1;
    ch2->InputGain1=1;
    ch2->InputOffset0=0;
    ch2->InputOffset1=0;
    ch2->OutputGain=1;
    ch2->OutputOffset=0;
    ch2->SlaveGain=1;
    ch2->BacklashMode=BACKLASH_OFF;
    ch2->BacklashAmount=0;
    ch2->BacklashRate=0;
    ch2->invDistPerCycle=1;
    ch2->Lead=0;
    ch2->MaxFollowingError=10000000;
    ch2->StepperAmplitude=250;
    ch2->iir[0].B0=1;
    ch2->iir[0].B1=0;
    ch2->iir[0].B2=0;
    ch2->iir[0].A1=0;
    ch2->iir[0].A2=0;
    ch2->iir[1].B0=1;
    ch2->iir[1].B1=0;
    ch2->iir[1].B2=0;
    ch2->iir[1].A1=0;
    ch2->iir[1].A2=0;
    ch2->iir[2].B0=1;
    ch2->iir[2].B1=0;
    ch2->iir[2].B2=0;
    ch2->iir[2].A1=0;
    ch2->iir[2].A2=0;
    EnableAxisDest(2,0);
    EnableAxis(0);
    EnableAxis(1);
    EnableAxis(2);
    DefineCoordSystem(0,1,2,-1);
    SetBitDirection( 43, 1);
    SetBitDirection(1024, 1);
    SetBitDirection(1025, 0);
    ClearBit(1024);
    /* while emergency stop wasn't pressed */
    while ( !ReadBit(143) )
    WaitNextTimeSlice();
    printf("EMERGENCY STOP PRESSED");
    /* disable all axises */
    ClearBit(144);
    ClearBit(145);
    ClearBit(146);
    ClearBit(147);
    ClearBit(148);
    DisableAxis(0);
    DisableAxis(1);
    DisableAxis(2);
    SetBit(1024);
    return 0;
    May 2006
    4045
    Hi mitzpetel,
    That all looks reasonable.
    If you run KMotion.exe at the same time are any messages printed on the Console Screen?
    Regards
    TK
    Jun 2013
    7
    The buffer time is 3 seconds.
    May 2006
    4045
    TK
    Jun 2013
    7
    I solved the problem.
    In the console it said that there is following error on the axis 1.
    I tweaked it a little bit and now it's fine.
    Thanks for the help.
  1. KFlop Kanalog and DMM
    By slonold in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-26-2014, 10:54 PM
  2. KFlop/Kanalog/Mach3
    By keithkyll in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-12-2014, 03:32 AM
  3. CNC upgrade with Kflop/Kanalog/mach3
    By Frank_W in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-26-2013, 01:04 PM
  4. My Kflop/Kanalog test bed
    By PEU in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-31-2013, 04:55 PM
  5. Retrofit old Cnc with kflop-kanalog
    By Scottburley in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-23-2013, 12:49 AM
