586,094 active members*
4,097 visitors online*
Page 1 of 3 123
Results 1 to 20 of 47
    Aug 2005
    828
    My DIY Stone Bridge Saw
    Here are some pics of the saw that my Dad and I built.
    Travel is 14x14 feet, spindle is 10HP, X Y drive motors are 3ph 1.5HP, the Z motor is a 1HP DC with brake. The table lifts up and rotates.
    Before this we were cutting with a rail saw,,,not fun.
    Still working on the covers for the THK rails......
    Attached Thumbnails Attached Thumbnails AllFront.jpg   ControlBoxes.jpg   ControlInside.jpg   ControlPanel.jpg
    Dennis
    Apr 2006
    1257
    Very Cool. One hell of a diy! Congrats on the (near) completion.
    Dec 2004
    1316
    wow!
    Jason
    Mar 2004
    1661
    That's really awsome! Do you have any picture on a ready piece?
    Aug 2005
    828
    ^^ Do you mean, stone that was cut on the saw? I'll take some pics tomarrow. But the edges are razor sharp and does not chip the buttom or cross cut corners. We used a rail saw like the Blue Ripper before this and this thing makes wayyyy nicer cuts.
    I'm felling a CNC next for the sink holes that every one, very dislikes doing.
    Dennis
    Mar 2005
    1136
    nice work, any build pictures or detail pics, ie frame, linear motion set up etc?
    Aug 2005
    828
    Here are some pictures of the bridge and Z axis and a few others. The big THK's are SR85 and rated at 37,000lb each block, I know it was thousand time over kill but they were available for a good price. The Z axis has a rotating nut ball screw and two SR20 rails with six blocks. The steel plate is 1" thick. We used a chain for the drive system because it was a easy alternative to other methods and we don't need positioning accuracy as with CNC. Everything turned out excellent. There are limit switches on all axis as I found that the motors will rip the chain like nothing if the bump stop is hit. The chain is iso 40 rated at 4,000lb. There is a green line laser to help with positioning the cut. The blade is a silent core 16".
    Attached Thumbnails Attached Thumbnails Bridge.jpg   Pump.jpg   ZAxis.jpg   Side.jpg
    Dennis
    Mar 2005
    1136
    thanks for details, what a beast!
    Apr 2006
    1257
    wow!!
    Feb 2005
    750
    Very impressive!
    Halfnutz
    Apr 2006
    1257
    Is there a coolant supply for while cutting?
    Aug 2005
    828
    ^^ Yeah, there is a 3hp water pump pumping 250 gal of water every 30 minutes. The water gets cleaned and recycled.
    It's pretty fun cutting with this thing
    Dennis
    Very nice! It certainly looks like a hugh improvement over the rail saw!
    Kevin Emery Jr
    GMR Quality Stone Products
    [email protected]
    c: 248-867-9875
    Jun 2005
    Any pics of the rotary table, I am building a brige saw also and am having a hard time coming up with the design of the rotary
    Thanks in advance
    Aug 2005
    828
    The table was a hard one, so we found a rotating base from a man-lift and used that. We were thinking for a long while on how to make it raise up a rotate. I'll make some pictures tomarrow.
    Dennis
    Aug 2005
    828
    Here are some pictures of the table up, the blue rams on both side are attached manualy to the table with the nuts on both side, it's a low tech way but works. My head was getting big from thinking to much on how to make the rams under the table.
    Attached Thumbnails Attached Thumbnails SawTable.jpg   SawTable2.jpg   SawTable3.jpg
    Dennis
    Dec 2006
    5
    Hey DennisCNC,
    Hey DennisCNC,
    Where are you guys located? I'd love to talk with you someday on the subject of building machines. Can I give you a call sometime?
    Robert
    336-364-1561
    www.robertmihaly.com
    Aug 2005
    828
    DRO Upgrade
    I added a DRO on the Y axis, here are some pics. Still working on how to mount the display an easy way.
    Attached Thumbnails Attached Thumbnails DROBolt.jpg   DroShaftTread.jpg   EncoderBolt.jpg   EncoderMounted.jpg
    Dennis
    May 2003
    109
    We need VIDEOS!!!
    Aug 2005
    828
    My camera when snowboarding for a few weeks, so when it's back i'll make a video.
    Here is a pic of a 3 volt regulator that I needed to make for the Green line laser as it died after a week of use at 5 volts. They said it was 5 volts and latter told me it was a new model and needs 3 volts, but the company sent me a new one! It's a LM317 regulator.
    Dennis
Page 1 of 3 123
  1. Replies: 0
    Last Post: 03-09-2011, 04:39 AM
  2. cnc for stone process
    By michel colonade in forum French
    Last Post: 10-14-2009, 07:06 PM
  3. Half bridge or Full bridge
    By bunalmis in forum CNC Machine Related Electronics
    Last Post: 04-13-2008, 08:11 PM
  4. Bob-Cad V18 Stone
    By Tazzer in forum BobCad-Cam
    Last Post: 09-19-2005, 05:11 PM
  5. CNC + stone
    By Pruski in forum Glass, Plastic and Stone
    Last Post: 08-15-2004, 07:21 PM
