I was poking around my WinCNC control and once again contemplating moving to Kflop based system with Kanalog. Looking at the specs again, I am not sure that kanalog will quite work, or maybe it will but not quite in a typical fashion?
The issue is that I have 5 servos to drive. 2 on the gantry, one across the gantry and basically 2 Z axis....labeled Z and W in WinCNC right now. It looks like Kanalog can happily drive these with analog +/- 10v but I am not sure on the encoder side:
the Kanalog - Connector Pinouts webpage states:
"Typically up to 4 encoder's A/B signals are connected to JP1 and any Z index inputs are connected to JP2"
So, does that mean if I ignore the index signal I can use 5 motors, but I would be limited to 4 if I used the index signal. The encoder output will be coming out of teknic servo drives not directly from the motor encoder. The drives will be controled by the analog signal in this scenario, but currently step and direction controlled.
If so, I can keep going and planning how I can best transition from one system to the other.
One last question. Where would the a spindle VFD typically be controlled from on a Kflop/Kanalog setup?
Thanks, Greg Facer
