586,551 active members*
3,462 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Full Depth of Tool
Results 1 to 6 of 6
    Nov 2012
    162
    Full Depth of Tool
    Hi guys!
    Need a bit of input from the gurus. I have a piece of soft H13 3.5x3.0x1.5 that I need to pocket into. I'm using a 4 flute 5/16 TiAN carbide end mill with a .8125 flute length and programming in X7 (Dynamic Area Mill). Now I'm doing a DOC of .230 as suggested by the Milling Advisor program.
    I have seen videos where they bury a tool to its full depth and do high speed milling in pockets. Is MasterCAM capable of doing the same to a depth of .800?
    The part has tight radii in the corners so the 5/16 endmill is what I chose (best fit). I know I could do a tool change starting with 1/2 or so but opted not to for no realistic reason.
    Milling Advisor suggests the following:
    SFM 95
    RPM 1159
    IPT .0007
    IPM 3.35
    Stepover 40% or .125
    DOC .234 or 75% dia.
    Entry angle 1* RPM 1159 and IPM 6.70
    Jun 2015
    32
    Re: Full Depth of Tool
    What's up Yoda,
    Not sure if you have ever used it before but try out the Trochoidal method.
    Nov 2012
    162
    Rugger? Not from XI?
    The dynamic area does use trichoidal. But I went ahead and tried to do a full depth cut...........actually .600 and it worked OK.
    Jun 2015
    32
    What do you mean not from XI?
    Nov 2012
    162
    Got a buddy from Xtreme Idiots named Rugger. Thought it might be you. If you swap the letters in your name........
    Jun 2015
    32
    Your buddy must play rugby also then but no I'm not that guy haha
  1. finish cut on profiles at full depth
    By brian257 in forum Rhinocam
    Last Post: 04-13-2015, 10:55 AM
  2. Tool offsets and Z depth
    By scubaru in forum MetalWork Discussion
    Last Post: 10-26-2014, 01:54 PM
  3. Eliminating tool markings on profile operations - full depth finish pass?
    By FoxCNC1 in forum Material Machining Solutions
    Last Post: 09-29-2014, 03:05 AM
  4. Tool Life vs. Depth of Cut on an X3
    By Kingjamez in forum Benchtop Machines
    Last Post: 10-24-2010, 09:00 PM
  5. Where to get a good/cheap z depth tool
    By Loading in forum MetalWork Discussion
    Last Post: 07-14-2006, 04:14 PM
