586,121 active members*
3,758 visitors online*
    Dec 2014
    X axis design help
    I am currently designing a 5' x 10' R&P machine.
    My question will no doubt get arguments from both sides of the fence.
    Which is a better design?
    20-25mm round supported rails with an R&P drive system or 1/4" 1018 cold rolled plate with linear carriages with an R&P drive system?
    I am looking for precision as well as smoothness in action. Cost is not a problem at this point in design.
    Thanx in advance!
    Re: X axis design help
    Imo, neither. Each has their own issues.
    If cost is not an issue, go with profile rail linear guides.
    May 2020
    8
    About the axis material. What is the best? P20 steel, H13 Steel or other?
  1. need Z axis design advice- dahlgren engraver -> full Z axis- how much Z travel?
    By lkasdorf in forum Uncategorised WoodWorking Machines
    Last Post: 05-11-2013, 02:50 PM
  2. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  3. Now....the Z-Axis Design ?
    By cncadmin in forum DIY CNC Router Table Machines
    Last Post: 12-07-2006, 08:00 PM
  4. Now....the Z-Axis Design ?
    By RakmUp in forum DIY CNC Router Table Machines
    Last Post: 11-29-2006, 10:24 PM
  5. 5-th axis design
    By georgebarr in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2004, 10:06 PM
