Guys, I have a real need for an automated cnc lathe. I have my little 80/20 lathe I built a few years back. It works fine, but has no auto chuck closer or bar puller/feeder. This means each cycle has to be started by hand. I need at least 300 turned parts each week. Sometimes a little more. Now that I have 4 positions on y Pulsar mill, that makes up for some lost time doing tool changes on it. It's time to tackle the other labor hog in the shop. The lathe.
I was intending to upgrade the 80/20 lathe, but think I will go a different route instead. Build a new lathe using the parts from the Torus. As you may know, it caught fire last year and had to be replaced. Ergo the Pulsar in the shop.
The insurance company finally released it to me last week to dispose of. John has seen detailed pictures and thinks it is too far gone to rebuild to try and recoup any money. So, totaled.
Some of the discussion about this is posted at the end of the 80/20 lathe thread here.
http://www.cnczone.com/forums/vertic...ml#post1710328
I picked up an old Hardinge DV-59 spindle head from Ebay for $399.00 plus shipping. Here is an image.
I intend to use the X and Y table off the Torus. Probably the stand too. I would mount the spindle at the end of the Y axis. Opposite where the column is. Not like a 4th axis. The spindle head requires a motor down below. Not only that but I am sure it is too heavy for the dovetails on the table of the Torus. Then I would still need a table and Z axis.
So, using Y as Z axis and the table as the X or cross slide, this will give me a bunch of room for gang tooling and accessories.
I would remove the column and spindle head from the Torus.
This build will allow me to keep using my lathe while I build this one.
I will moch it up in CAD art some point. Thoughts are welcome guys.
