Hi, this is my first post (after writing on welcome forum). :wave:
I have a serious problem with my machine , which took two months trying to solve (nuts).
I have already contacted with Sieg service (being very supportive), but still not get the problem solved.
Defining the problem is simple: After a long 5.000 -100,000 machining lines, the machine loses the zero point (between 0.6 and 2.5 mm in X and Y).
My setup: Sieg H250 high speed.
servomotors: Adtech ACH-09075DC-T
Servo Drivers: Adtech QS7AA020M
Control Panel: SEC 500 (Shanghai Electric)
CAM Software: SprutCAM 9
The problem occurs with some programs. I made some +100,000 lines without any problems and other 8,000 lines with a large deviation. It seems that movement tends to occur with "organic" lines, but not with those lineal, circular or elliptical.
I've done several tests and adjustments:
- Adjusted electrical parameters of rigid, and acceleration, without any change (the machine is going now smoother than ever )
- Adjusted Backlash (nothing changes)
- Speed setting ... it seems that, with less speed, the error is slightly lower. (about 10 or 20% less)
- Found that no loss of directional steps cycles for several hours in which the values of the control panel and the servo driver match:
Example:
G54G94
S500M03
G01 X-20 F2000
G04 X3 (3 seconds stop)
G01 X0
M99
... and with multiaxis, high velocity (15m/s) without stop:
G54G94
G00 X-50 Y-50 Z-50
G00 X0 Y0 Z0
M99
... and no zeros losing.
Next thing left for me to see if everything is tight. I doubt that this is the problem because programs like that I put above, with accelerations and deaccelerations it's has, should have lost zeros, but has not.
My suspicions are now with the interference (I have a welding shop next door, wall to wall);
But mostly I suspect programs since the problem occurs with some, but not others. I have no other milling machine to test it, so I would appreciate if any could try it and keep an eye to the program I update (air milling), to check for error on postprocessor (this one give me about 1,5mm off in X and Y axis).
The program max moves are X50 Y-50 Z-1 (milimetres), about 13 min of go.
Also add, that the problem occurs while milling steel... and milling air (with spindle OFF).
Any appreciation or contribution is welcome.
Thank you very much in advance. And so sorry for the long post.
