586,068 active members*
3,775 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Zenbot 4848 CNC Router... A (4) axis is not working with y axis motor
    Jun 2015
    Hello,
    I have a Zenbot 4848 CNC Router using Mach 3.
    On this model there are two stepper motors to control the y-axis, (aka Y axis & A axis). If I take off the A axis stepper motor from the table I am able to control the machine just fine. However, the A axis motor is suppose to work in conjunction with Y axis motor. I can jog any motor in Mach 3 separately. If I leave the A axis stepper motor on the machine, the machine stalls in the y direction cause both the A axis stepper motor is not moving.
    The CNC router is suppose to use both motors to move the gantry in the same direction (y axis).
    Attached is a picture Port and Pins settings in Mach 3. Is there a change in the settings to make?
    If the video works too, the A axis motor is sitting on the table to allow the gantry to move.
    Feb 2011
    109
    Re: Zenbot 4848 CNC Router... A (4) axis is not working with y axis motor
    Hi --
    Quote Originally Posted by spitz2015 View Post
    Hello,
    Are you using the Zenbot provided XML profile file for the 48" machine? The screen shot shows mach3mill which may have been inadvertently loaded when you started Mach3 or perhaps you have renamed your Zenbot profile. Just checking.
    --Rich
    Jun 2015
    Yeah, I honestly figured out what I was doing wrong. I simply did not load up the XML file in Mach Loader from Zenbot. I should've paid closer attention to the instructions.
    Feb 2011
    109
    Great! Glad you got it resolved.
    --Rich
  1. Items I need to buy not included in Zenbot 4848 kit?
    By 007lab in forum Zen Toolworks
    Last Post: 07-28-2021, 08:12 AM
  2. Budget shopping-Autocad,zenbot 4848,mach3, and __?__
    By 007lab in forum Uncategorised CAM Discussion
    Last Post: 02-07-2015, 11:03 PM
  3. Pro 4848 kelininc electronic z axis inconsistent...
    By peterkallas in forum Uncategorised WoodWorking Machines
    Last Post: 12-14-2013, 07:33 PM
  4. Pro 4848 z axis issues
    Last Post: 12-06-2013, 12:29 PM
  5. LC1390 Z-Axis motor not working
    By QuestSuperElf in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-12-2013, 08:50 AM
