586,117 active members*
3,394 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > home/limit switch questions
Results 1 to 2 of 2
    Apr 2007
    6
    The application eng. at Dmm said the home- limit switch would be located in the center of the travel of the table then the pc/breakout board limit the travel by counting. I was wondering if the count failed or programing error what would stop table motion. with no hard stop switches at the limits of travel a stop failure would be a disaster. any ideas ? thanks Chris
    Jan 2008
    66
    Re: home/limit switch questions
    Hard limits at the end of travel is the norm. Depending on your machine, one switch on each end of travel or one switch in the middle that gets triggered with trip blocks on each end will work. Soft limits within your travel limits will prevent you from jogging into the switches. Not sure what machine controller you are using but it should be configurable for homing and limits..
  1. Is it possible to use the home switch as the limit switch as well?
    By Darc in forum Mach Software (ArtSoft software)
    Last Post: 11-02-2012, 06:25 PM
  2. limit switch- home switch
    By normd in forum CamSoft Products
    Last Post: 05-17-2008, 12:56 AM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
