586,567 active members*
3,655 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Connecting 3 wire DC Brushed servo motor with SnapAmp
    Mar 2010
    20
    I have a question for connection the 3 wire DC brushed motor I bought : KL23-130-60 with SnapAmp : High-Torque Stepper Motor, Stepper Motor, Driver, Stepper Motor kit, DC Servo Motor, DC Servo Motor kit, Stepper Motor Power Supply, CNC Router, Spindle, and other Components. Stepper Motor | Stepper Motor Driver | CNC Router | Laser Machine | 3D Prin
    Attachment 282258
    Should I connect White (ground) and Red (+) or Black (-) and Red (+) to my controler SnapAmp ? (I have 2 output for DC Servo from my controler) :
    Thanks you very much for your help.
    Regards.
    24223
    Re: Connecting 3 wire DC Brushed servo motor with SnapAmp
    The Red+Black should go to the controller output, the white (GND) should go to an earth ground point.
    Unfortunately in N.A. GND does not always mean earth ground, it is used as a double purpose meaning as supply common and for earth ground.
    This can often lead to confusion, especially for the un-initiated.
    Another common area of confusion is when the earth ground symbol itself is (mis)used for supply common for a schematic, when in fact the chassis or logic common symbol should be used.
    Al.
    Albert E.
    Mar 2010
    20
    Al.
    Thanks you very much, I was confusing with the GND = earth...
    Thanks !
    Regards.
  1. Connecting encoder with kflop and snapamp with closed loop mode
    By rdpdo in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-23-2015, 06:04 PM
  2. Motor/SnapAmp question
    By frontrange in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-11-2015, 03:13 AM
  3. SnapAmp brushless motor example
    Last Post: 02-07-2015, 09:36 PM
  4. Servo motor ground wire and Gecko 320
    By Novett in forum Gecko Drives
    Last Post: 12-30-2014, 02:33 AM
  5. Servo tuning with SnapAmp
    By powerr in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-23-2011, 08:16 PM
