Re: how agressive have made your Speeds and feeds on the 2400?
Cutting speeds and feeds has more to do with the cutter than the machine itself.
The machine spindle motor size and rigidity of the column tells us how big of a cutter it can handle.
A typical 2 flute HSS 0.250 end mill should be spinning at 4800 rpm and feeding at 12 to 24 ipm.
Depth and width of cut is dependent on the machine, but you should be able to go 1D and 1W to use a cutter properly.
A carbide cutter can go much faster and quicker. In this example a 0.250 IMCO M202 can be spun at 12224 rpm and fed at 24.4 ipm.
Timothy
Dyna Mechtronics DM4400, Bridgeport Discovery 300, HAAS VF-0E, HAAS VF-2D
BobCad 16, 20, 24 and now V25
