586,461 active members*
4,830 visitors online*
Results 1 to 2 of 2
    Jun 2015
    B Axis Adjust
    B and Z are not perpendicular. Do you have a procedure ? It is a FA 800 3 piece Curvic
    thanks, Carl
    Feb 2009
    6028
    Re: B Axis Adjust
    B&Z? did you rotate B 180 and see if you get the same reading? If so, adjusting the B won't help. You either have a leveling problem on the machine, or something much worse going on.
  1. How to adjust the feed speed on the x axis.
    By Børge in forum Mach Lathe
    Last Post: 09-16-2013, 11:05 PM
  2. Servo gain adjust on Z axis ?
    By mishikwest in forum Haas Mills
    Last Post: 05-14-2010, 08:35 PM
  3. i need to adjust axis velocity FANUC 21 i
    By mantenim in forum Fanuc
    Last Post: 11-04-2009, 10:38 PM
  4. 8020m - unable to adjust creeping axis
    By alphonso in forum Fagor Automation
    Last Post: 06-02-2009, 01:52 PM
  5. Z axis how to adjust it
    By cob in forum Mach Mill
    Last Post: 07-10-2008, 10:59 PM
