586,103 active members*
3,547 visitors online*
Page 2 of 3 123
Results 21 to 40 of 45
  1. #21
    Jun 2015
    17
    Re: fanuc 6m locked parameters
    when i do so, i only see macro up to 551.
    i found them under the button ''set" when i press it twice.
    or does my machine don,t have more?
  2. #22
    Aug 2011
    2517
    if it has any, macros would only be present on a working machine.
    there is a parameter to check and if it is set it will say use macro when T code is read and another one for M code.
    if they are set then you should have tool change macro, otherwise you dont have it.
  3. #23
    Jun 2015
    17
    monday we get a mechanic from fanuc, so lets hope he can solve it.
  4. #24
    Oct 2014
    137
    But what version your M63 software and what chips (numbers) are installed on your ROM PCB?
    If I have in such composition this series/version then I can try to look into ASM code. There is well seen that disturbs a parameters entering ;-).
  5. #25
    Jun 2015
    17
    > Motherboard: A16b-1000-0030/06c
    > Machine data:
    > Fanuc tape center model d
    > 6m
    > Series m63
    > Typ A04B 0034 A003
    > Ser 530432
    > Attachment 290418
    Attachment 290420
    control: 6MB2.
  6. #26
    Oct 2014
    137
    If your version software is M63 Vers.02 I try to look access for parameters 120,122 in ASM code. Version you can seen when CNC power on with pressed Emergency button.
  7. #27
    Oct 2014
    137
    nijhuis,
    I have checked software m93 vers.02 for address to cell parameters P120, P122 and P123.
    These cells are absent in internal parameters table for this reason in this software to him haven't access.
  8. #28
    Jun 2015
    17
    oke, so the don't have a function? do you something about the error 451 t servo?
  9. #29
    Oct 2014
    137
    Yes, to these parameters locked entering and from software to him haven't request to read.
    For decision of the problems the error 451 for 5-th axis it is necessary following:
    - Check all 5-th axis parameters (DMR,CMR, e.t.c.);
    - Check pulse coder for 5-th and his wire;
    - Check driver for 5-th axis and his connections;
    - Check diagnostic N804, must be a value close to zero (Adjustment by resistor RV2 Offset, under Par.007 #7=0). All rest additions is described in Maintenance Manual.
  10. #30
    Jun 2015
    17
    the problem is solved.
    3 parameters are set on on the rong place. and parameter 84 for the zpoint ref needed another value.
    thanks for al the suggestions.
    greetings albert
  11. #31
    Oct 2014
    137
    Only I do not understand as parameter N84 can influence upon alarm >> error 451 t servo?<<
    Possible this can to explain us two unknown and secret parameters!? ;-)
  12. #32
    Quote Originally Posted by agering View Post
    Dear Agering.
    Pls help me how to see asm code???
  13. #33
    Oct 2014
    137
    I use one of the free version IDA Pro for this process.
  14. #34
    Aug 2018
    44
    Please tell me if your Type D is a DC or a AC spindle ? ( Is she Green or white ?) The tool changer are not exactly the same
  15. #35
    Sep 2018
    15
    Hello gays.I need parameter fanuc 6t-b.
    Sent from my SM-G355H using Tapatalk
  16. #36
    Nov 2018
    11
    hello
    If programs are written to use macros and subprograms , is there a way to figure out what those macros settings and subprogram are. I am afraid that when sending programs(someone else wrote) to the machine , i coming to the conclusion i might of forced macros and subprograms out of the memory to make space . I removed two programs and began looking for area where the macros are stored. The machine is a Amada OCTO 334 NC punch press, using a Fanuc 6M controler . I dont have the Fanuc 6m operators manual which covers the macros , nor can i find it online. please someone help
  17. #37
    Dear Agering.
    Can you teach me how to see ASM code??
    My mail: [email protected]
  18. #38
    Sep 2012
    216
    I know this is an old post but i have been trying to edit the 0000-0005 parameters on an old Matsura but they are locked. Does anyone know the procedure for editing these parameters?
    Thanks and cheers
    Regards Bob
  19. #39
    Apr 2009
    1379
    I am not aware of locked parameters on the FS6. Turn the PWE switch (on motherboard) ON, select MDI/ESTOP and edit the parameter.
  20. #40
    Sep 2012
    216
    Quote Originally Posted by memoryman View Post
    Sorry i was referring to the 6mb control
    Regards Bob
Page 2 of 3 123
  1. Fanuc OT Wear Offset page locked???
    By grumpy74 in forum Fanuc
    Last Post: 02-21-2015, 08:14 AM
  2. System/option parameters locked on ospU10L
    By Zachmuscle in forum Okuma
    Last Post: 10-18-2014, 05:17 AM
  3. Fanuc i18 Locked Read and Ladder
    By mirc899 in forum Fanuc
    Last Post: 09-23-2013, 09:29 PM
  4. Replies: 2
    Last Post: 04-21-2010, 04:28 AM
  5. Replies: 3
    Last Post: 04-01-2009, 11:06 PM
