oke, so the don't have a function? do you something about the error 451 t servo?
Yes, to these parameters locked entering and from software to him haven't request to read.
For decision of the problems the error 451 for 5-th axis it is necessary following:
- Check all 5-th axis parameters (DMR,CMR, e.t.c.);
- Check pulse coder for 5-th and his wire;
- Check driver for 5-th axis and his connections;
- Check diagnostic N804, must be a value close to zero (Adjustment by resistor RV2 Offset, under Par.007 #7=0). All rest additions is described in Maintenance Manual.
