Hi all,
I have been playing with my CNC router for a while and can get it to do what I want most of the time. There is still a lot to learn though I feel.
One question I have is about the RPM's of the spindle. In the software I use you can choose a setting, but this is meaningless when machining as the spindle just runs at whatever speed the dial on the control box is set at.
Is this correct operation? Do I just control the spindles speed via the knob on the control box? If so, that seems like a lot of guess work as I have no idea maximum speed is.
If not, how do I set the spindle speed correctly? Do i set the knob half way and then play with the software? It just seems the router software Mach 3 ignores the speeds set in my cam software.
Andrew
PS, I have a basic 3040T router
