586,521 active members*
3,663 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > taper threading for FANUC Oi mate TD
Results 1 to 2 of 2
    Dec 2005
    74
    Hi guys,
    Here a program for 3" NPT pin.
    O0002
    (PROGRAM NAME - 3 NPT PIN)
    (DATE=DD-MM-YY - 08-06-15 TIME=HH:MM - 10:40)
    (MCX FILE - D:\HAVEN\O0002.MCX)
    (NC FILE - D:\HAVEN CNC\3 NPT PIN.NC)
    (MATERIAL - STEEL INCH - 1030 - 200 BHN)
    G20
    (TOOL - 1 OFFSET - 1)
    (DESBASTE PDJNR 2525 M15 INSERT - DNMG 120408)
    ( REFRENTADO 0.020 )
    G0 T0101
    G18
    G97 S413 M03
    G0 G54 X3.7 Z0. M8
    G50 S1000
    G96 S400
    G99 G1 X2.9375 F.01
    G0 Z.1
    ( DESBASTE D0.060 )
    X3.6202
    Z.11
    G1 X3.4202 F.012
    Z-.2706
    X3.4488 Z-.3013
    G18 G3 X3.4564 Z-.3174 R.0412
    G1 X3.54 Z-1.655
    X3.74
    G0 Z.11
    X3.5004
    G1 X3.3004
    Z-.1422
    X3.4402 Z-.2921
    X3.6402
    G0 Z.11
    X3.3807
    G1 X3.1807
    Z-.0138
    X3.3204 Z-.1637
    X3.5204
    ( ACABADO )
    G18
    G0 Z-.018
    X3.3426
    G1 X3.1426 F.01
    X3.4106 Z-.3055
    G18 G3 X3.4164 Z-.3177 R.0312
    G1 X3.5 Z-1.6553
    X3.7
    M9
    G28 U0. V0. W0. M05
    T0100
    M01
    (TOOL - 7 OFFSET - 7)
    (ROSCA EXTERIOR 10-11.5NPT INSERT - TNMA 43 11.5 NPT EXT)
    ( ROSCA 3 NPT-8 TPI )
    G0 T0707
    G18
    G97 S400 M03
    G0 G54 X3.7 Z.2481 M8
    G76 P010029 Q0. R0.
    G76 X3.310 Z-1.625 P0950 Q0068 R-.057 F.125
    M9
    G28 U0. V0. W0. M05
    T0700
    M30
    I checked the toolpath on CIMCO edit and look the threading process, attached files. I can`t found my mistake (see tool retract).
    Aug 2011
    2517
    Re: taper threading for FANUC Oi mate TD
    Your Q and R should not be 0 (in real life machining situation).
    Regardless it doesn't work in the simulation even with Q and R set to some amount.
    I tested a proven program that works on real CNC lathe in Cimco Edit 7 (build 7.55.08 the latest release)
    and it doesn't work so threading in Cimco Edit 7 is borked.
    Report the problem to Cimco and they will hopefully fix it.
  1. Replies: 5
    Last Post: 08-17-2014, 01:11 AM
  2. G76 taper threading
    By jschmid in forum Fanuc
    Last Post: 12-29-2013, 04:42 PM
  3. Looking for taper and threading attachments
    By klysons in forum Uncategorised MetalWorking Machines
    Last Post: 03-20-2007, 03:29 AM
  4. Taper Threading
    By motorworks in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-16-2006, 12:01 AM
  5. taper threading using G76 on Fanuc OT
    By sinha_nsit in forum Fanuc
    Last Post: 03-23-2006, 11:31 AM
