-If my rails are 4x8 and the dimensions of my table top are 4x8, how do I mount the rails to the table? If necessary, I could sacrifice a few inches from the rails, it's not that crucial.
[Judging from the picture I found online:
cnc mogul 4x8 cnc machine - RC Groups this machine uses intermittently supported round rails. The main thing you need to assure is that they are mounted flat and level, and a constant distance apart. In practice, that probably means getting them as close as you can with whatever levels and straightedges you've got, shimming if necessary, and running the gantry back and forth as you gradually tighten things down, so it continues to be able to move freely.]
-Vacuum tables. Do you NEED one? Do you clamp it to your table top? Mount the rails to it? Is one necessary for a beginner?
[You don't need it. It's primarily useful for doing cutout work on large flat sheets. If that's the sort of work you plan to do, it's best to build it as an integral part of the table when you're building your machine. But if you didn't do that, it will eat up valuable headroom to add it now. For smaller things, you can build a vacuum pod that you can mount or dismount as needed.]
-I was told to use NEMA24 Stepper motors.
[That's probably NEMA 23.]
I have yet to find a router that will fit in the 3.5" router clamp my machine came with, so I'm not positive on how much weight these will be moving yet. (Open to good suggestions for routers, and starting bits.)
[If you can afford it, a 3-phase spindle with VFD is better than a router designed to be run by hand. They're more powerful, with better bearings, easier to speed-control and last longer.]
-CNC Moguls are a very "Plug and play" setup, so I have to choose all my electrical components and build a control box. Stepper online has 3 axis kits that seem like they will have what I need. Anyone have good or bad opinions on these?
3 Axis CNC Kits- StepperOnline
(I don't know how to add links)
