586,075 active members*
3,768 visitors online*
    Jun 2015
    4
    Required laser cutter coolant flow rate?
    Hi All,
    I'm new to the forum and what a fantastic resource it is! I have been playing with CNC machines for a few years, but I am new to laser cutters having only owned one for roughly a month.
    I have searched for some info on this, however what I have been able to find is somewhat inconclusive... I am wondering whether there is some kind of rule of thumb as to appropriate flow rate of coolant through a CO2 laser tube, for a given power output, in order to cool it sufficiently?
    I have been having some issues with my 50W Chinese machine, where the power seems to drop away to nothing within a couple of minutes of cutting. If I switch the machine off and run it again a little while later, the power is back, however it once again quickly drops off to nothing. I suspect that something is over heating and causing the power to degrade, and the obvious culprit I would assume is the tube.
    It is winter here at the moment and my workshop is a nice cool 15C (59F) and I am not noticing much change in the temperature of the coolant when I run the machine, though the volume of coolant is fairly large at approximately 30L (8 Gallons). The coolant I am using is distilled water with a small amount of antifreeze added.
    I measured the flow rate of the coolant through the system, and determined it to be 1.66L/min. Do those of you with experience think that my issue is likely too low a flow rate of coolant? Or does it sound like the degradation in power am seeing is happening too fast for it to be an issue with the tube overheating?
    I made a quick video of the machine cutting a scrap of plywood to demonstrate how quickly I am loosing power. The machine is running at 99% power in the video.
    Thank you for any thoughts or suggestions you may have.
    Chris Barnes
    https://youtu.be/KNmreFfNgak
    Dec 2013
    5
    Re: Required laser cutter coolant flow rate?
    Quote Originally Posted by CBarnes View Post
    Hi All,
    Chris Barnes
    hello, i have same problem like yours, did you check the amperemeter? if mine was suddently drop until half, but i haven't check it, talk to the seller, he told me to check the ground, but the ground is ok... also the power supply, nothing suspicious... i still wait for my technician back from other service job to looking what happen with the machine.
    Jun 2015
    4
    Quote Originally Posted by amders View Post
    Unfortunately my machine doesn't have a built in current meter, perhaps I'll have to hook up a multimeter to the tube. The power supply was the other thing I suspected as I imagine it could get quite hot.
    I'm interested to hear what the technician determines the problem to be with your machine.
    Nov 2008
    382
    hi there
    from my experience the flow rate should be around 6 to 9l/minute in order to avoid overheating the tube what could destroy the tube very fast.
    to hook up a mA meter is a must to avoid overcurrent because the controller does not regulate this efficient enough. to hook up a analog 50mA meter , they are cheap just cut the black or blue wire and connect there.
    if one or both of this parameter , current and or temperature goes over the limit for 50W tube max 20mA and max 78 F the tube will be unusable or destroyed in hours .
    greetings
    waltfl
  1. CTX 510 Coolant pressure and flow rate is too low
    By Mahmoud_hola in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 02-10-2015, 09:14 AM
  2. COMPACT STAND AND ACCESS ENCLOSURE COOLANT FLOW
    By keen in forum Tormach Personal CNC Mill
    Last Post: 11-12-2014, 11:17 PM
  3. Specification on Tormach Hi-flow coolant pump?
    By Jeff E. in forum Tormach Personal CNC Mill
    Last Post: 07-29-2013, 04:46 AM
  4. K-15 No Coolant Flow
    By eustisfixer in forum Hyundai Kia
    Last Post: 08-08-2012, 01:18 PM
  5. How to control the flow rate in a 3-phase pump?
    By Ed from NY in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2011, 07:45 AM
