Trying to use a G1 with z moves for a bar puller. When this line is reached it stops and shows the correct distance to go but will not move. If I turn it on DRY RUN it will move and do the cycle fine. I'm using the same program for 3 other machines with Fanuc controls. I even tried MDI ( G1 z-.1 F50. ) and it would not move with out DRY RUN either. Is this a parameter that is turn off ?
