586,061 active members*
4,414 visitors online*
IndustryArena Forum > CAM Software > Mastercam > When Drilling is there a way to select by point color?
    Apr 2008
    87
    Similar to how you can chain a specific detail that repeats several times under contour without selecting the detail over and over again one at a time, can you select say only the red points for a .250 hole and then come back and select only the blue points for a .125 hole? Right now I am just using different levels for each dia.
    Thanks!
    Jul 2014
    29
    Re: When Drilling is there a way to select by point color?
    Yes, you can use Selection Mask, then you can choose your point via: color, layer...
    Apr 2008
    87
    Perfect! That does exactly what I need, Thanks for the help!
    Dec 2008
    3109
    Quote Originally Posted by GiangTheTool View Post
    or....use the QM icons on the lower RH side of the screen
    - R-click the icon to select all of that criteria....L-click to set the mask, which allows you to ONLY select the entities that suit that mask
  1. Lasercut 5.3 start point and end point not matched and curve line not smooth?
    By shizyo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-21-2019, 11:26 PM
  2. 6 How to Select Objects of Same Color
    By thunderlaser in forum Laser Control Software
    Last Post: 12-11-2013, 08:37 AM
  3. Replies: 5
    Last Post: 09-25-2013, 05:20 PM
  4. how to select curves for drilling?
    By dwneumann in forum MadCAM
    Last Post: 03-15-2012, 09:27 AM
