586,356 active members*
2,905 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > What are your thoughts one this kit??
    May 2015
    7
    G'day,
    I'm new to all of this stuff, And I'm building a plasma/router table.
    It it will be 3 axis setup but with dual drive on the X. So I'm looking at a 4 axis kit to suit.
    what are your thoughts on this type of kit? Good drivers? Good breakout? Good power supply?
    CNC KIT 4 Axis TB6600HG Motor Driver 0 2 5A 4 NEMA24 Stepper Motor 36V10A PS | eBay
    appreciate any help!
    Tyson
    Aug 2004
    780
    Re: What are your thoughts one this kit??
    Forget anything 4-axis.
    Forget anything usb.
    Forget anything TBxxx.
    Cheap, good drivers are the 2M542 series.
    Use 48 V DC.
    May 2015
    7
    Hi hanermo,
    thanks for the advice! But why do u say forget 4 axis? I am planning on running dual drive on the x which I believe counts as a 4th axis yeah?
    As for the breakout board and drivers, I have bought a set of 2M542 drivers with parallel breakout like you suggested.
    I've also got a set of 567oz-in NEMA24's on their way.
    Hopefully everything matches up and works!! :-/
    One other thing... I was going to gear down the motors to screws with belts and pulleys, but the screws and motors I'm looking both require a pulley with a 10mm bore... Which seem to be hard to find. Most look like 6.35, 8, or 12mm. Any ideas?.
    thanks!
    Oct 2013
    18
    I am not sure I understand Han's comment. If you are running dual steppers on the same axis you can slave them but that can lead to other issues. How big is your table going to be? How heavy is your gantry going to be? All these questions need to be answered before you choose the steppers. I have a 4' x 4' cnc, an old Warthog that I am rebuilding, it currently has 2 steppers on the same axis and they are slaved. I plan on changing that to a 4 axis setup. My machine has Nema 34's, per the calculations I have run I will need a 140 watt stepper, I am leaning towards a low inductance 600 oz stepper settup from Leadshine. As to volts higher is better to a point.....
    YMMV
    Bryan Rocker
    May 2005
    1397
    Cheap crap from china. But at least it's not a TB6560.
    If you fry a multi -axis driver, you must replace all drivers. Individual drivers can plug and play.
    Usb used to be bad. Usually ok now.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. V25 Thoughts So Far
    By SeanDa in forum BobCad-Cam
    Last Post: 06-27-2012, 06:15 PM
  2. CNC to NC Thoughts
    By Fish4Fun in forum Open Source CNC Machine Designs
    Last Post: 03-24-2011, 06:11 PM
  3. Thoughts on What We Do
    By SPEEDRE in forum DIY CNC Router Table Machines
    Last Post: 07-20-2009, 01:36 PM
  4. Think im going to get a X4... any thoughts?
    By simila95 in forum Benchtop Machines
    Last Post: 04-16-2009, 04:16 PM
  5. CNC thoughts
    By Tekko in forum Benchtop Machines
    Last Post: 02-12-2007, 02:20 PM
