586,076 active members*
4,119 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 Initial Setup Troubles
Results 1 to 16 of 16
    Question G540 Initial Setup Troubles
    Hi guys.
    This is my first CNC project since doing 3D printing for a while. I ordered a kit with motors and a gecko from automation technologies. It looks good but I can't seem to get it up and running on mach 3. It's plugged into a parallel port, estop jumper is in place, end stops are shorted to ground as per setup guide and the ports and pins are according to geckos guide. Why doesn't this work.
    I have a video that's much easier to explain than me typing it.
    Thanks for all the help!
    https://www.youtube.com/watch?v=BUgv4Dee8lk
    Re: G540 Initial Setup Troubles
    Did you read the G540 manual? Specifically, steps 2 and 3, and the troubleshooting section.
    If the light is red, it's not a Mach3 issue.
    Also, those twisted wire connections to that motor are a very bad idea. At a minimum, they should have some wire nuts on them.
    Completely disconnect the motor, and get rid of the red light before you go any further.
    Feb 2014
    94
    First thing first , forget the cross over for the E Stop had the same issue . Spend the $4.00 here N C Emergency Stop Switch Push Button Mushroom Push Button 4SCREW Terminal AP | eBay
    then go to home depot and get a pvc 4 in. x 2 in. Junction Box ( similar to this Cantex PVC Junction Box ) or at least under $20.00 cut a hole in it and mount it to it . $20.00 or so later and wired right had no issues after that .
    So I get the green light when I turn the charging pump off. I will attach some images of my mach3 setup.
    Your port address is wrong, for starters.
    Also, your video says you have a new parallel port.
    Is it a PCI parallel port?
    You also said the COM port was set to EPP?
    A parallel port is not a COM port, and an add on card is not usually configurable in the bios?
    It's an onboard Parallel port, and yes in bios it's set to EPP, Here's the settings/ options.
    How would I find the correct port address?
    It is cuttently EPP
    EDIT: Just tried it on port 0x378 still nothing.
    I also checked continuity on the parallel cable and it was as it should be
    Sep 2010
    717
    Quote Originally Posted by 154james View Post
    It is cuttently EPP
    0x378 is for your COM port, check the LPT port address in device manager.
    Current build: http://www.cnczone.com/forums/diy-cnc-router-table-machines/264838-new-machine-desing-quot-cnm13-quot.html
    Quote Originally Posted by hub View Post
    Just checked the device manager, I found this: Attachment 283280
    Tried 0x778 and still nothing
    Sep 2010
    717
    What does the LPT card software say as the parall. port address?
    (Also sorry made a mistake, your com is at 0x3F8)
    There is no software for it, it's on the MB. I'm running this on an older Dell Optiplex, has a parallel port on it.
    Sep 2010
    717
    I don't have any exp. with geckos... But my best guess is something is wired wrong.
    The port setting can be verified by turning on/off an output in mach3 and measuring from the LPT port, should go on/off.
    I'm getting nothing from the LPT port, what's next?
    Try 0378 in the port address.
    Run Drivertest.exe in the Mach3\ folder, and see what happens.
    The program runs and I get the "Mach 1 test complete" dialogue box but then when it continues to get to the driver install my machine blue screens, I'm gonna try loading XP on a partition and see if that fixes it
    Is your version of Windows 7 64 bit?
    If so, then the parallel port will not work.
  1. Mach3 Initial setup with or without license?
    By johnd in forum Machines running Mach Software
    Last Post: 02-22-2015, 08:04 PM
  2. Initial setup of used tormach?
    By widget_maker in forum Tormach Personal CNC Mill
    Last Post: 03-08-2014, 12:36 AM
  3. Newbie Q regarding initial setup
    By czralv in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-12-2013, 03:10 AM
  4. G540 Initial Set-up Fault Mode
    By sst4270 in forum Gecko Drives
    Last Post: 11-04-2012, 05:30 AM
  5. Help in initial setup.
    By hjl4 in forum Viper Servo drives
    Last Post: 01-18-2011, 11:20 AM
