586,075 active members*
3,832 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi Seiki Repair / Service / Support
Page 3 of 9 12345
Results 41 to 60 of 180
  1. #41
    May 2008
    4
    Re: Hitachi Seiki Repair / Service / Support
    HITEC-TURN 23SII When we press standby, hydraulic punp starts and shuts off within seconds.
    Unable to swith screen from the initial startup menu.
    Uncertain if serial no 2320 is actual serial number, plate is elegible this is the
    only number on the plate.
    Unknown alarms for this one because we can not pass the initial start up screen.
    HITEC-TURN 20SII When we press standby, hydraulic pump starts and shuts off within seconds.
    These are the alarms we are getting;
    392 Z-Axis TG disconnected
    390 ServoPack Alarm
    310 Power for Servo not supplied
    Need help getting these two machines running - We are located in Lula, GA 30554
  2. #42
    Dec 2009
    539
    Sent you a PM - could be a few things, but need more info before I can get a better idea of what the issue is. take a look. Ill post results when we get it figured out.
    John
  3. #43
    May 2008
    4
    Basically what I need is for you to come to Lula Georgia and see if these two machines can be fixed and running.
    Call me if you would like 770) 869-0945
  4. #44
    Apr 2018
    E-mail and Phone #
    John
    can you provide me with e-mail and phone number.
  5. #45
    Dec 2009
    539
    Re: E-mail and Phone #
    Hello
    I sent you a PM with my info
    John
    Quote Originally Posted by Boeing2018 View Post
    John
  6. #46
    Nov 2012
    14
    Hi, where in the vm50 I can find the servo endcoder batteries ? I have attached the cabinet photo
  7. #47
    Dec 2011
    Dear Jonh,
    I need all pararameter , SLbus table, ladder , AB phase , timer , counter, table.
    Machine Hitachi seiki model HT20S, control SEICOS LB Mark2 ,
    M16-II Ver 7.5.
    The baterry died and the machine not ready.
    I got the ladder but after putting it with the YUYU software the machine gives me the alarm Z80 CPUClick image for larger version.
    My email: [email protected]
  8. #48
    Dec 2009
    539
    Tony
    I sent you an email - take a look, will need some more info before i can help out
    John
  9. #49
    Hi dears
    I have a hitachi Seiki center with HBG630 model and Fanuc 15M control.already cleard the Ram and I don't have any backup of it. Now I have a problem on tapping cycle,Can anybody help me about the programming tapping cycle please?
    In addition cycle g84 doesn't work and tool change doesn't reserve and ready io program.Thanks a lot.
  10. #50
    Dec 2009
    539
    hello!
    What do you mean cleared the RAM? What was the issue that caused you to clear the data? What data did you have to enter?
  11. #51
    Hi friend
    The memory of Ram card with A16B 2200 013 was cleard and the service man reinstalled
    The Ram card and wrote the program macros.
    But now I knew there are problem on tapping cycle and tool changing.
    G84 doesn't work. And I have to work with G84.2 when start the program tapping the axis move to forward and when it will backward , the tap will break.and the other problem is on the tool changing. When the program start, the machine have to ready next tool for next op but it doesn't do this.
    Help me plz.
    Thanks guy.
  12. #52
    Sep 2018
    Hi i ma new in this forum, Someone can i help me becouse a have a pin lathe hitachi seiki ht-25s and i don`t have the manuals technicians , i can not to star
  13. #53
    Sep 2011
    4
    I have Hitec turn 20SII with a 173 parameter error. I need parameter sheet. My sn. Is HTS2399HL. Van you tell me how to fix. Any help would be appreciated.
  14. #54
    Dec 2009
    539
    Hello
    send me a PM with more info
    John
  15. #55
    Brunocnc28 Guest
    Hi
    Is There somebody who have knowledge on a Hicell with complete Nec control ( Nc and servo, only spindle is yaskawa 626VM3)
    Thanks.
  16. #56
    Dec 2009
    539
    Hello!
    yes I do - if you want you can PM me your email and Ill help you out!
    john
  17. #57
    Nov 2012
    14
    Few days ago got one scary situation, after probing part on vm50 when I hit cycle start Z Axis instead of going on to Z0 g28 , dropped into the part like it's freefalling , immediately pressed the estop and there was nc servo alarm and 1219 z innefective current over . Had to restart the pc because I couldnt jog the tool of the part. IT looks like the brake on the Z Axis didnt worked as its should ? Is it a sign of the nc control ending it's lifespan or servo ? When the machine idles on the screen I can see 65% when it was jogged to up or 50% when was jogging down Z Axis load . It's 98 model.
  18. #58
    Nov 2018
    Hello i'm french i need your help . Can you help me for a problem with hitachi seiki seicos 10. Thank's
  19. #59
    Nov 2012
    14
    My Hitachi vm50 got Orange screen , machine was staying idle then suddenly black screen appeared and everything was shutdown. Is it something with graphic card ,or LCD ? Or its the NC Control that is down?
  20. #60
    Dec 2018
    Hello, I bought a Hitachi hg400, fanuc 16m+siecos 10M controlled machine.The parameters of the machine were lost in transit.I need the parameters of this machine.I hope you can help me. Thank you.My email is [email protected]
Page 3 of 9 12345
  1. Hitachi Seiki Service and Support!!!!!!!!1
    By Hitachi_man in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2024, 12:29 PM
  2. Hitachi Seiki Electronic Repair
    By controlsgadgets in forum News Announcements
    Last Post: 03-14-2022, 12:02 PM
  3. Hitachi Seiki Gearbox Repair
    By DPGE Rebuilds in forum News Announcements
    Last Post: 06-13-2006, 10:49 AM
  4. Hitachi Seiki Gearbox Repair
    By DPGE Rebuilds in forum MetalWork Discussion
