586,094 active members*
4,050 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi Seiki Repair / Service / Support
Page 9 of 9 789
Results 161 to 180 of 180
  1. #161
    Dec 2009
    539
    Re: Hitachi Seiki Repair / Service / Support
    Hello!
    PM me your email and I can help, there are a few sets of batteries in that control, but could be other issue
  2. #162
    Quote Originally Posted by shas595 View Post
    Hello
    send me a PM with your contact info so I walk you through the process
    Hi. Need a help¡ In Hitachi Seiki VS50 SEICOS 18M, I'm getting D404.7 LS Tool unclamp alarm. I've checked signal status of all limit switch and sensors related to tool change. Kindly support.
  3. #163
    Dec 2009
    539
    Quote Originally Posted by mathalaikanna View Post
    Send me a PM with your email and I will assist
  4. #164
    Sorry I couldn't PM. Settings were compromised i guess. My mail
    [email protected]
  5. #165
    I upload Backup for HITACHI VK45II and VM40II in my home page.
    You can find it in Index of /~aike/docs
  6. #166
    May 2023
    HITACHI SEIKI VG45 STANDBY problema
    Buongiorno,
    Mi lampeggiavano i numeri sul monitor allora o spento e riacceso completamente il cnc, ma a questo punto cliccando il tasto standby mi rimane lampeggiante quinti fa partire la pompa idraulica ma non i motori/azionamenti sembra che ci sia un'interruzione, tentano di avviarsi ma dopo circa un secondo cadono( non ho allarmi) tranne quelli vecchi tipo controllo olio lubrificazione che non vanno via perchè non riesco a superare la fase di accensione potete aiutarmi grazie
    Su LADDER vedo un'interruzione
    sul parametro 380.6 cos'è questo parametro?
  7. #167
    Hi!
    Please write in English. Google show me bad translation from Italian.
  8. #168
    May 2023
    3
    Hello. I can't open these files. Can you upload in another format? Thank you
  9. #169
    May 2023
    3
    Quote Originally Posted by =aike= View Post
  10. #170
    Hello.
    We have Hitachi Seiki Vm 40II with Seicos 3 control. I just enabled the DNC and I would really appreciate it if somebody could let me know which parameter I should change to enable helical interpolation, spiral milling. It is an option and as far as I know one of the parameters higher than 9000 should be changed.
    Thank you.
    - - - Updated - - -
    Hello.
    Thank you.
  11. #171
    Jan 2024
    Hi all. Please tell me what to do, an error has appeared on the machine 1040 (8000) ASV1C alarm ram error.
  12. #172
    Dec 2023
    If you changed the main board, it is likely a software problem. Send me a PM with your email and I will contact you direct
    Hello shas595
    Thanks for your time. I hope you can help me
    I have the same problem (DIRECTORY BROKEN). It is a Hitachi lathe that lost parameters. We have the parameters printed. They were loaded manually.
    but in the end this broken directory alarm appears
    my email is [email protected]
  13. #173
    Dec 2009
    539
    Hello
    Send me a PM with your email and ill help, it wont let me send one to you
    Quote Originally Posted by JaniJenko View Post
    Hello.
    Thank you.
    - - - Updated - - -
    Hello.
    Thank you.
  14. #174
    Dec 2009
    539
    Alarm is usually due to SAMS2 card going bad. PM me your email for additional assistance
    Quote Originally Posted by DMus View Post
  15. #175
    Jan 2024
    Hi all. Please help someone who can, Hitachi Seiki HiCell 23B. Please share the machine parameters, my B axis is not displayed and the sub spindle is not controlled.
Page 9 of 9 789
  1. Hitachi Seiki Service and Support!!!!!!!!1
    By Hitachi_man in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2024, 12:29 PM
  2. Hitachi Seiki Electronic Repair
    By controlsgadgets in forum News Announcements
    Last Post: 03-14-2022, 12:02 PM
  3. Hitachi Seiki Gearbox Repair
    By DPGE Rebuilds in forum News Announcements
    Last Post: 06-13-2006, 10:49 AM
  4. Hitachi Seiki Gearbox Repair
    By DPGE Rebuilds in forum MetalWork Discussion
