Hi - I am interested in building a simple prototype pick and place system for small objects. I have done fixtures with pneumatics, but would like to try steppers.
I have quite a bit of experience with PLC based data acquisition and control...DIO an Analog Out, and some PLC experience with the same.
After reading until my eyes started to bleed ... I am here to ask for suggestions.
My 1rst choice would be to simply use IO from PC DaQ, o PLC to run a "stepper sub routine"... similar to an "mdrive". Or use Automation Direct Sure Step and one of their higher end controllers, with simple "click" plc. BUT that gets expensive quickly as you add axis.
I don't need the fastest, best solution.. just something that would be flexible to learn with.
Are there any options for low cost programmable controllers. or motors with onboard controllers (I am not interested in an Ardurino solution)
I would like a balance between "off the shelf" like Automation Direct, or Mdrive and cost.... and additional hardware. I already have IO available, but nothing with a CTRIO or true high speed ouput.
