Originally Posted by
angelw
Hello cosco,
The PWE bit is 8000.0, but you will find this parameter in the "SERVICE" and "SETTING" parameters. The PWE bit can't be set in the "SERVICE" parameter area. To set the PWE bit, proceed as follows:
1. Put the control into MDI Mode by either selecting MDI, or pressing the Emergency Stop.
2. Select the Setting screen by pressing the "SETTING" Soft Key.
3. Enter 8000
4. Press the Soft Key "INP-NO".
5. Press 1 and then the "INPUT" Soft Key to change the PWE bit. The control will enter an alarm status.
6. Press the Function Menu key and the Soft Key is changed to function select
7. Press the "SERVICE" Soft Key and then press "PARAM" Soft Key to select the Service Parameter screens.
Regards,
Bill
