If you don`t set the limits correctly in Mach then you won`t see the toolpath displayed correctly in Mach.
Best to set everything the same, so if you have 18 inches of physical movement in the Y on your machine and your machine is correctly homed then it will be sitting at the full extent of the axis travels.
All you need to know if moving away from that "MACHINE ZERO" will be a minus - or a plus + direction, that`s easily checked using your jog keys on your keyboard (Assuming you have set those).
Once you know the direction then you can set your Max Soft and Min Soft values in Mach, you can now also use the same values to set your machine limits in BobCAD.
If your machine moves in a minus direction away from the Y limit switch then set the Y Max Soft to 0.00 and the Min Soft to -18.00
Do the same for the X axis, you should see in the Mach toolpath window a rectangular box that is outlined with a dotted line, that will represent the actual size and shape of the bed of your machine.
Now you can easily set the toolpath in any position you like using your G54,G55 etc "Fixture" settings in Mach, this means that you will ALWAYS draw your part in the same place in BobCAD, some people for example always use the bottom left corner, due to the way I set up vises and machined fixtures on my table I always draw my parts on centre Zero in BobCAD, that`s just my personal preference, it is easier to use a corner, usually the Bottom Left which means you will always be drawing in the top right quadrant in BobCAD.
Hope that is of some help
Regards
Rob
:rainfro: :rainfro: :rainfro:
